ignition removal
Discussion in 'The Hokey Ass Message Board' started by kyle paul, Aug 6, 2009.
  1. delete
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    You should feela little spring tension in one hole , that's the one to use. Then rotate it further CCW, should then release.
  3.
  4. Why are you changing the cylinder? Is it because you can start it with a screwdriver? I put a new cylinder in my truck with no change in screwdriver capability. Waste of money on my truck.
  5. shortbed65
    shortbed65
    from ne Ill
    with the two holes -- its the one left of the other- 12 o-clock rather than the 2 o-clock hole ,your pin will "bounce" (pin over spring) - push in then rotate left only a 1/16" then pull out
  6. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I thought they came out in the start position.
  7. shortbed65
    shortbed65
    from ne Ill
    You know you got me curious , I was describing my daily '63 C10 ,so I went to my "65 and tried that and it's the same procedure
