Identify this, Your Good!
Discussion in 'The Hokey Ass Message Board' started by Rumbles, Jun 11, 2009.
  1. Rumbles
    Rumbles
    <!-- / icon and title --> <!-- message --> I just got my block back from the machine shop and happened to find something blocking the block drain. I removed the frost plug near the drain hole and after painstakingly making two cuts with a hack saw this is what I pulled out. Any ideas of what it could be, probably been there since it was built?
  2. James427
    James427
    Looks like part or a robotic boring tool for oil passages.
  3. 49ratfink
    49ratfink
    what kind of motor is that?
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Looks like something that was going to ruin your day somewhere down the road
  5. Pete1930
    Pete1930
    from Boston
    Is it cast iron? Maybe a riser from the casting process that was for some portion of the inside?
    Pete
  6. 34toddster
    34toddster
    from Missouri
    Those are in there for part of the sand cast set-up, A lot of blocks have them.
  7. ? what ever it is dosen't look like it belongs there Good luck
  8. Your machine shop never pulled the frost plugs? :eek:
  9. SLCHC-CHIEF
    SLCHC-CHIEF
    from S.L.U.T
    dont know but its out now right. so dont worry haha
  10. Marty McFly
    Marty McFly
    Yeah, what he said. :eek::eek::eek:!
    What else didn't they do?
    Marty McF.
  11. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    Wow I'm still with everyone else...odd they didn't remove the frost plugs.
  12. jetmek
    jetmek
    i often find chunks of heavy gage wire in flatty's... used to hold the molds together
  13. Thats what I'd say. I work at a machine shop, "sticks" like that loosen up and come out all the time.
  14. Yep, I've had some experience around casting and foundaries for newer engine blocks and can say with almost certainty that is a runner (section in mold where molten iron/steel travels from one section to another). What I can't say with certainty is how it got in there.
  15. Rumbles
    Rumbles
    Yup it's cast, its a 1960 Dodge 230 Flathead, and I'm not very happy about getting the block back after being boiled with the frost plugs still in, no doubt that was a waste of money. I'm pulling all the plugs and checking it over along with everything else he did.
  16. All I know is that now you will have to install it back into your engine, exactly where it came from! All traditional, correctly built engines have these parts.
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Core plugs people..they were never ment to relieve the block if it froze.
    and yeah i would be wondering if they really replaced your Core Plugs too,or how through of a cleaning job they did of your block
    The Myth of Freeze Plugs
    All blocks have Core Hole Plugs, commonly called "freeze plugs." For many years it was believed that these pressed-in plugs were put there to pop out if the coolant became frozen in winter, thereby saving the engine block from cracking apart.
    This never was true, because there is no way to protect the intricate cooling passages of an engine from cracking if coolant freezes. Although mechanics and owners saw some of these plugs pop out when engine blocks froze, no such design was ever intended. The so-called "freeze plugs" are, in fact, plugs that seal up core holes in the block that designers put there for several purposes. Some core holes are put there to provide a rigid point of attachment for machinery jigs that hold the engine precisely during drilling and boring operations. Other holes are there to provide access to drill or bore oil galleries and other fixtures. Once these operations are completed the holes need to be sealed, and that is the job of the pressed-in plugs.
    Whenever an engine block is rebuilt the core hole plugs should be replaced. Because they are thinner than the surrounding casting the plugs tend to rust out sooner, so failure to replace them often results in leaks.
    sorry its a pet peeve of mine:eek:
  18. Just a piece leftover from the casting process, see it in old Chrysler blocks all the time. :p
  19. kustombypook
    kustombypook
    Hell yeah! It takes a big fuckin' hammer and punch to remove them, so I doubt a little a frozen water is going to push them out.
  20. Frosty2
    Frosty2
    from Hambone,IN
    Frozen water is powerful.Ask anyone who replaced a frozen pipe in a crawlspace.
  21. Us guys at the flat earth society still call them freeze plugs.
  22. Von Rigg Fink
    Von Rigg Fink
    from Garage
    im not doubting that..
    but if coolant froze enough to push out that plug..you got bigger problems..cracks..
    still was not the purpose
    sorry my intention was not to de-rail this thread...
    i think what the other guys were saying is its part of the sand casting process (also those holes are where the sand from the casting process gets out of the hollow block) that little cast iron "thread" was part of the mold process.
  23. Straightpipes
    Straightpipes
    I found a 1957 silver dime in a flathead block once:eek:
