Identify this engine Please
Discussion in 'The Hokey Ass Message Board' started by Dave Gray, Nov 27, 2012.
  1. Dave Gray
    Dave Gray
    I am trying to identify this old 4 cylinder engine. It is an overhead valve
    engine. The only Identification that I can find is a logo that is cast in to the block and head. The logo is a large S with a F inside the top loop of the S and Co. in the bottom loop. I will try to attach a photo or 2.
    Any help would be appreciated.
    Dave Gray
    Carlisle, Pa.
  2. young'n'poor
    young'n'poor
    from Anoka. MN
    I can't help ya but ill bump it for you.
  3. propwash
    propwash
    from Las Vegas
    last photo looks like someone crafted an overhead oiling system for it. Also noted is that the rocker arms and valve stems don't see too overly fond of each other's personal space.
  4. young'n'poor
    young'n'poor
    from Anoka. MN
    Is there any markings on the block?
  5. Can't help, but I did notice how far the rockers are off from the center of the valve tips ?!?!?!?!?!
  6. Dave Gray
    Dave Gray
    The only markings are the S F Co. cast in to the block. (Photo)
    Dave
  7. the-rodster
    the-rodster
    Am I seeing 4 valves per cylinder?
    Rich
  8. Atwater Mike
    Atwater Mike
    Not unless you're seeing double, Rich.
  9. Dave Gray
    Dave Gray
    The rocker arm assembly and overhead oiler assy is just sitting loose on
    the head.
    Dave
  10. What markings are on that generator? Interesting setup.
    Looks British or French, for whatever reason.
  11. Dave Gray
    Dave Gray
    The metal tag on the generator is unreadable. The info appeared to
    have been painted on rather that engraved.
    Dave
  12. propwash
    propwash
    from Las Vegas
    Nonetheless, that does not explain how far off they are - look at first two on the left of the photo....no amount of installing/tightening down on the shaft is going to cure that offset.
  13. nathan
    nathan
    from minnesota
    Kinda looks like an old borgward engine[​IMG]
  14. It is a rare Sanford and Fitch racing engine, used @ indy and daytona in the mid '40s. ;)
    There that'll get you back up there.
  15. propwash
    propwash
    from Las Vegas
    racing engine with a dynamo/generator? From the looks of the grime packed on there, I'd guess "teardown" at the end of the season was not part of the plan?
    And I'd think Fitch would want at least as large a billing for his F as Sanford has with the S. Some kind of car or pickup engine, nathan's suggestion of Borgward seems a lot more plausible than the Indy suggestion.
  16. Dave Gray
    Dave Gray
    It does have similarities, but many differences also.
    Dave
  17. the-rodster
    the-rodster
    Ahh, that's the pushrods on the other side.
    Where are the spark plugs?
    Rich
  18. That is why it is a Sanford and Fitch and that grime was because during the war they didn't clean the brickyard, gas was rationed. And anyone that could operate a broom was busy building bombs.
  19. Dave Gray
    Dave Gray
  20. landseaandair
    landseaandair
    from phoenix
    I think we need more clues. There also looks to be some sort of i.d. tag riveted on the crossmember.
  21. Someone knows what it is if we can just keep it on top where they can find it.
  22. Dave Gray
    Dave Gray
    The brass tag on the front crossmember is stamped 6962.
    Dave
  23. Definitely out of some sort of right hand drive vehicle judging by the clutch shaft sticking out of the right side of the bellhousing.
  24. It,s LHD , No big deal, just a Simca France engine. Simca 5 was a French Topolino. Simca 8 was a little bigger than the 5. Then there is the Simca Aronde with the souped up Rush engine. This looks like something inbetween. Bet Metalshapes knows.
  25. landseaandair
    landseaandair
    from phoenix
    Must be the serial number.
  26. metalshapes
    metalshapes
    That was my first thought too.
    But I cant find a pic that matches it.
    Bet Bluto knows... :D
  27. Yeah, i did a bit of google searching but could,nt find an exact match either. There is a Simca 6 as well and i completely forgot about Bluto,s knowledge of the the little French cars. Sorry about that Jim.
  28. Dave Gray
    Dave Gray
    I am amazed by the depth of knowledge of HAMB members. I have not heard of
    some of the engines that you talk about.
    I suspect that someone will identify this creature.
    Dave
  29. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    BTT
    I'm curious too.
  30. Dave Gray
    Dave Gray
    Given the physical size of this engine, is it possible that it was used in a truck rather than a car?
    Dave
