Technical Identification of Steering Parts
Discussion in 'The Hokey Ass Message Board' started by Charlville, Apr 23, 2014.
  1. Charlville
    Charlville
    Hi
    I'm led to believe that I have later front spindles on my 1929 Model Sport Coupe. I'm trying to identify what I have, as the ball joint has excess play and there is also some play in the kingpin. I wonder if anyone can help with identification via the attached pictures please?
    Apologies for the state of the steering gear, will be cleaning soon :)
    Regards
    Kevin
    West Berks UK
  2. Andy
    Andy
    I can't see much in your pics. It looks like 37-41 spindles and 42-48 brakes. The drag link looks to have a regular later tie rod end on it. If the spindles have round flanges, I did ID them.
  3. Bruce Lancaster
    Bruce Lancaster
    I think I see round, and thrust bearing above lower spindle boss.
    Drag link is most likely composed '35-48 Ford tie rod parts. Kingpins probably '37 type.
    All parts look to be well rust-proofed!
  4. landseaandair
    landseaandair
    from phoenix
    Can't help but notice the odd strap and loose bolt between the spindle and backing plate, could be a potential steering hazard. Also should probably make some tabs for the loose brake lines at the frame.
  5. doctorZ
    doctorZ
    X2. Without a good pic of the spindles from the back to see the shape I can't be certain though.
  6. Charlville
    Charlville
    Hi All
    Thanks for the help and observations so far I've taken a few more pictures as requested.
    Thanks in advance
    [​IMG][​IMG][​IMG][​IMG]
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    37-41 Spindles.
    39-41 brake backing plates, heel of shoe adjustments at bottom.
    What in the hell is that shim looking crap shoved between the axle knuckle and the slpindle back?
    I'll answer my own question... it appears to be shims to take up slack/wobble in the kingpins. Take all that stuff apart, clean it up, and see if the kingpin bushings and pins are slap worn out or the hole in the axle boss is wallowed out, it will be one or all of that.
  8. Charlville
    Charlville
