Ideas for clutch fluid reservoir
Discussion in 'The Hokey Ass Message Board' started by blackjack, Aug 14, 2008.
  1. I need a clutch fluid reservoir for a Girling master cylinder. It will have to go on the firewall of my 27 T Model Ford so I'm looking for something a bit funkier than the white plastic reservoirs that normally go with them. Any ideas?? I can adapt stuff by welding on outlet pipes and brackets.
  2. How about the good old Ford fruit jar master cylinder?,,,,no reason why you can't use it for a clutch fluid. HRP
  3. Tulsa oldskool55
    Tulsa oldskool55
    If you want something to go with your other aluminum pieces you could use the inline can on a/c line and they can be had cheap or free.
  4. tbill
    tbill
    from central ny
    gut an old coil, then mount it and your actual coil on the firewall, that'll mess with people.
  5. stagernwings
    stagernwings
    from tx
    i like the speedway sprint car filler tank for the rearends it looks as it did 40 years ago and cheap .c
  6. tomslik
    tomslik
    but mount both upside down and use the "coil wire"/hose from the clutch "coil" to feed the clutch m/c...
    that come out right?
  7. the first thing that came to mind for me was a grenade
