Projects Ideas for a non abrasive circular saw blade to cut open a hood?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Jan 8, 2025.
  1. Okie Pete
    Okie Pete
    Pictures of car needing surgery would be helpful
  2. oldolds
    oldolds
    I have used almost all of the above methods. I would probably use a sawsall in this case
    Sharpone and Budget36 like this.
  3. Bert Kollar
    Bert Kollar
    air chisel and sheet metal tool best choice
    lostone, 427 sleeper and Budget36 like this.
  4. 1971BB427
    1971BB427
    from Oregon
    Even holesaws or step bits can create some small sparks, but if you keep a can of WD40 or spray cutting fluid to spray the holesaw or step bit it will cut easy, and eliminate almost all sparks.
    I'd do 4 holes located at the corners of the opening you need and then use tin snips to connect 3 sides, and just bend up the 4th side.
    Budget36 likes this.
  5. Rickybop
    Rickybop
    You get skinny-ass Rubberband Man Rickybop to climb under the car and up into the engine compartment armed with a pair of pliers.
    I may ache a bit these days but I'm still pretty limber.
    I'll just need two days off afterwards.
    And lunch.
  6. Budget36
    Budget36
    When it warms up a bit (still in the 30’s) I’ll head out with a hole saw and a stool.
    I’m vertically challenged so need some elevation!
    LWEL9226 and Sharpone like this.
  7. RodStRace
    RodStRace
    That means you can chop the top even more, you should be used to cuttin' steel! :D
    Best of luck, it seems that almost every tool known to cut has been offered!
    If @Rickybop comes over, I want video!:D
    Sharpone, Rickybop and Budget36 like this.
  8. Rick is on the way and he ate his spinach! HRP
    [​IMG][/QUOTE]
  9. Rickybop
    Rickybop
    Well shiver me timbers...
    BJR, hotrodjack33, Okie Pete and 2 others like this.
  10. Budget36
    Budget36
    Well poop. My hole saw arbor needs a bigger chuck than 1/2 inch.
    Time to get creative.
    Rickybop likes this.
  11. Way back in the 70s, that's how we cut aluminum siding on remodels. Plywood blade installed backwards, hoisy as hell!
    Algoma56, Sharpone and Budget36 like this.
  12. woodiewagon46
    woodiewagon46
    from New York
    I don't know if some firefighters use an axe, but as a retired firefighter we carried an air chisel kit on our rig and we used an adaptor on an air tank to power it. Works great on any sheet metal part with zero sparks.
    Algoma56 and Budget36 like this.
  13. saltflats
    saltflats
    from Missouri
    What's wrong with a hammer and a sharp chisel.
    Kerrynzl, Algoma56 and Budget36 like this.
  14. Budget36
    Budget36
    Probably nothing, but I’d rather drill some holes, get access to the lower structure, switch out hole saws and cut a hole around the latch catch bolts.
    Hammer and chisel is work, drilling is a lot less work. :)
  15. RodStRace
    RodStRace
    Depending on the latch, once you get access to the backside, you may be able to release it or unscrew the plunger. Think a bit before going all Mongo on it.
  16. 1971BB427
    1971BB427
    from Oregon
    Get a smaller holesaw! The 1/2" and 3/4" EMT holesaws are 7/8" and 1.125" blades, and both use small arbors that fit even a 1/4" chuck. Or just use a step bit that's either 7/8" or 1 1/8".
  17. Ebbsspeed
    Ebbsspeed
    I have cut through hundreds of feet of corrugated steel panels with a circular saw. I put the blade on backwards and let 'er rip. Use an old blade, and a high tooth count works best.
  18. Tickety Boo
    Tickety Boo
    from Wisconsin
    What year and model of car or truck? Someone here on the HAMB might have done this an easier way ;)
  19. RodStRace
    RodStRace
    @Tickety Boo , he's avoided any reference to the vehicle. Sensing the worst, I'd guess a Yugo. Thing is, he's probably trying to lift the back edge! :p
    Tickety Boo and Budget36 like this.
  20. Budget36
    Budget36
    lol. It’s OT. The question was what to to use. I found a smaller hole saw arbor that will work on my chuck. It’ll be open today.
    Asked a guy at the grocery store (similar year truck) if he’d pop his hood for me so I could take a look.
    Should go quickly today.
  21. There you go, first do a reconnaissance mission, then you know what you're up against.
    RodStRace and Budget36 like this.
  22. Budget36
    Budget36
    Well, no holes, etc. just a better set of eyes and a good flashlight.
    Mercy.
  23. Joe Blow
    Joe Blow
    Trip through the grill?
  24. RodStRace
    RodStRace
    @Rickybop did the trick, but the video is on OnlyFans. :D:p
    He's hoping it pays for lunch.
    Rickybop, Sharpone and Budget36 like this.
  25. Budget36
    Budget36
    Yes, better and curious yes than I had, stopped by, he wanted to know what I was doing. Nice fella about my age.
    He looked, asked if I had a flashlight. Went and got one, then pulled the grill out, there were three bolts, a few minutes later with a 10mm socket, hood was up.
    Sharpone, Joe Blow and RodStRace like this.
  26. Budget36
    Budget36
    @Rickybop stood me up, had a 7 course lunch meal waiting for him, well, 6 course meal, I had one of the beers… ;)
  27. twenty8
    twenty8
    spit coffee laughing gif.gif ............ Sorry.:rolleyes:
    RodStRace, Sharpone and Budget36 like this.
  28. Budget36
    Budget36
    Spelling and proofreading is not my strong suit;).
    But on the bright side of things, I can now use my 1/2 cordless and make a big hole when needed!!
    Sharpone likes this.
  29. Joe Blow
    Joe Blow
    Well....if you ever lock your keys in the trunk.....you're loaded for bear now.....:)
  30. Budget36
    Budget36
    Pickups have no trunk.
    Damn I dodge the bullet there!!
    Sharpone and Joe Blow like this.
