ID this tool?
Discussion in 'The Hokey Ass Message Board' started by Wild Turkey, Dec 30, 2013.
  1. Wild Turkey
    Wild Turkey
    Lot of folks are guessing what specialty this multi-tool is designed for, or is it just a "multi-tool"?
    The guy who posted the pix I copied said it came from a HVAC shop but it's got stuff they wouldn't use.
    Any good ideas?:confused:
  2. Gerry Moe
    Gerry Moe
    Kind of resembles a horse shoeing tool, back in history sheet metal workers were derived from blacksmiths, sheet metal workers became HVAC installers, iron workers also.
  3. whtbaron
    whtbaron
    from manitoba
    Maybe, but I would be more inclined to say wooden shingle repair. You can split them to size, nail them or remove nails all with the one tool.... maybe...
  4. Gerry Moe
    Gerry Moe
    Makes sense
  5. Damn! I'll bet you're right!
  6. I'm thinking it's a multi tool,,I believe one part of the handle is also a screw driver,the other part of the handle could be used as a pry bar,,the top looks like a hatchet,hammer and the opening is used as pliers.
    I remember my granddad had a tool like that in his wooden tool box. HRP
  7. 39 Ford
    39 Ford
    Saw a tool like that on an old Farm, cedar shakes if I remember correctly.
  8. Bulletnose26
    Bulletnose26
    Looks like it could be used to open a "3 port eddy" fire hydrant.
  9. 29AVEE8
    29AVEE8
    I have had one for many years. It is stamped "STAHL" on the hammer head portion. I doubt that it ever did anything very well but it has a hammer head, hatchet head, straight bit screwdriver, nail puller, serrated opening like a pipe vise, straight blade cutter, and wire cutters all incorporated into it. Kind of a Swiss Army knife.
  10. bustedwrench
    bustedwrench
    Looks like a pair of fencing pliers to me.
  11. hotrod40coupe
    hotrod40coupe
    Looks like a fence tool to me.
  12. Toymont
    Toymont
    from Montana
    Fencing tool has a pointed end where the hatchet head is, My guess would be for ceder shakes
  13. R Pope
    R Pope
    One of those "golly-gee" wonder tools that do absolutely nothing well.
  14. 29AVEE8 posted pics of a stahl. A google image search of "Stahl combination tool" reveals a lot of info. Seems this is one of the multitudeof "one tool fits all". Combination tools of this type appear to have been very common, manufactured by numerous companies.
  15. It does have Germany stamped in it,so probably quality tool.I can see
    lots of "multi tool" uses maybe even hvac but shake or shingle work
    w/o a firm handle I wouldn't count on it,could work but not this tool.
  16. perfect tool for any farmer to keep in his pocket, open a bail, fix fence, turn a water valve with no handle, break ice out of a trough, drive a nail 3/4 the way in then bend over, strip a 3/8" nut, turn a 3/16" bolt till it breaks, scrape mud [oops not mud] from your boots, tighten barn door clasp etc...
  17. whtbaron
    whtbaron
    from manitoba
    Well... I've farmed for 30 yrs and I've never owned one...still going with the cedar shingle weapon.
  18. thomas.gusky@gmail.com
    from DuBois, PA
    methinks it's a plumbers universal spanner wrench/nutcracker/crableg meat separator/nuclear cheese processor and can double as a paper weight....seen em before..I think that's it..definite maybe..Moses Lonagain.
  19. I am thinking something to do with stringing telegraph or power line from years ago .. the center hole would run in lags on the cross bars, the hammer head to drive in the insulator; and the axe end for whittling the pole face to match the cross arm surface.... and the obvious wire cutter/stripper.
    ..... do I win?
  20. whtbaron
    whtbaron
    from manitoba
  21. silversink
    silversink
    Rare Gerber prototype for their million dollar multi tool
  22. Just FYI - "Stahl" in German means "Steel."
