ID tag
Discussion in 'The Hokey Ass Message Board' started by Ice man, Aug 19, 2009.
  1. Ice man
    Ice man
    I need an ID tag maker. The numbers on my 29 Pk Up are not visible now that the fire wall is painted. So i'm lookin for a presentable tag with the numbers stamped on that are easly seen. Any one out there. Iceman
  2. rd martin
    rd martin
    from indiana
    see rich b on here, he will fix you up! hes in the classifieds.
  3. Bruce Lancaster
    Bruce Lancaster
    If you are talking about the patent plate, little zinc plate with Ford logo and lots of numbers, that is available repro for cheap. It has NO ID function...nothing on it is peculiar to the car. Only other firewall numbers are date stamps. only serial number for ID and registration is on frame and on the original engine block.
  4. the-rodster
    the-rodster
    www.macsauto.com
    body id plate A18651, buck sixty five
    take it to a trophy shop, have it engraved, rivet it to the firewall, done.
  5. mj40's
    mj40's
    Just understand that these repo VIN plates may not be legal as an ID plate in most states. Check yours before buying. They want the real thing or numbers from the motor or frame as from the factory. GM was one of those that actually put plates on the passenger cowl or passenger side kick plate with rivets or screws.
