Id plates for dash switches?
Discussion in 'The Hokey Ass Message Board' started by staleg, Jan 29, 2013.
  1. staleg
    staleg
    I would like to have some kind of id plates for the switches and indicator lights on the dash. I'm thinking of aviator/military inspired signs that says "Lights" "Wipers" etc.
    One small sign for each switch /indicator light.
    Anyone that makes stuff like that?
    Or should I just leave it as it is?
  2. NEWFISHER
    NEWFISHER
    from Oregon
  3. chaos10meter
    chaos10meter
    from PA.
    Or check out your local engravers , like a jewelry store or a trophy shop.
  4. nicksduce
    nicksduce
    from indiana
    don't know myself but in the world today these would cost $10,000
  5. squirelmurphy
    squirelmurphy
    from O.C.
    Go to your local trophy shop. They are surprisingly cheap.
  6. spooler41
    spooler41
    My God man, you need a lay out diagram and a menu hanging from the dash.
    ...............Jack
  7. alchemy
    alchemy
    Out of a '40's-50's wooden boat. Pic might be hard to read, but they say "wiper" and "navigation". Also come in other markers like "bilge pump".
  8. My po' boy 1940's approach to labeling (grease pencil & drafting tape);
  9. DFH-GMC
    DFH-GMC
    from Texas
    I would leave it, looks good as is.
    Why make it easier for someone else to drive?
  10. hotrod mike
    hotrod mike
    My local UPS store makes those engraved plates. Maybe try that.
  11. CutawayAl
    CutawayAl
    from MI
    In addition to the various things a trophy chop can do, there are shops doing laser etching and cutting work that isn't overly expensive.
  12. propwash
    propwash
    from Las Vegas
    I owned a sign company in Kodiak, Alaska and we had a pantograph. We made placards like that for fishing boats, pleasure boats, aircraft of all description, SeaLand was a client for their tractors, as were all the canneries and processing plants for forklifts. As suggested, any trophy shop should be able to accommodate you, and the plastic laminate comes in more colors than you can imagine.
  13. 53fordcustom
    53fordcustom
    Ditto
  14. The37Kid
    The37Kid
    Do you plan to align the +'s in the Phillips head screws? Bob
  15. traffic61
    traffic61
    from Owasso, OK
    I was digging through the junk drawer the other day and found a sheet of self adhesive labels that I purchaed from Aircraft Spruce about 25 years ago. They probalby still have them, although they are probably not nifty enough for that nice panel.
    I had a larger "Spins Prohibited" placard on the console of my old Corvette, my pilot buddies thought that was pretty cool.
      55.5 KB
  16. 5window
    5window
    Here's a pair that I designed (made a full sized drawing for them),then had a local promotions company make for me. They did a really nice job,seemed keen on the challenge and charged less than $20 for the pair.
  17. DD COOPMAN
    DD COOPMAN
    Hey...back-off! I'm the only one that does that. DD
  18. propwash
    propwash
    from Las Vegas
    Do you mean there are people that DON'T do that? Every switch plate in my house, garage and hangar has the screws aligned, even on the cover plate for any and all breaker panels. Yeah...it's anal...but it's what to do.
  19. CutawayAl
    CutawayAl
    from MI
    Rolls-Royce actually did that with all screw and bolt heads, at least on the pre-WWII cars.
  20. Steves32
    Steves32
    from So Cal
  21. Steves32
    Steves32
    from So Cal
  22. AllSteel36
    AllSteel36
    I'll try to get pics, but in my Dad's Pete, I used stainless strips and letter stamped them, used model paint brush (black paint) then wiped fast with a rag...it left the black paint in the stamped area and stands out nicely.
    But you dash, I think brass would be a better finish.
  23. Ya mean there's people out there that don't line up all the screws ? does that mean I shouldn't have spent so much time "clocking" the caps on my valve steams?
    but any way man what a dash, I know they make "key tags" or "sample tags" usually brass mini placards (rectangular about 5/8" x 1 ") with a hole for mounting on top, I can get ya a picture and may have a few kicking around yet , p.m. me if interested :)
  24. staleg
    staleg
    Thanks for all the creative answers! :D
    A trophy shop was a good tip.
  25. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    I have to say that is one awesome dash. Great job!
  26. i.rant
    i.rant
    1. 1940 Ford
    Points off if you don't do it at classic car shows I'm told.
  27. charlieb66
    charlieb66
    With that many gages, warning lights, and switches to keep tabs on, you may be a danger to others drivers on the road.
  28. 5window
    5window
    Just cause they're there doesn't mean you have to look at them. Think of all the clowns that drive at dusk, in the fog or in the rain without their lights on! Usually they have grey cars.
  29. plym49
    plym49
    from Earth
    Your dash, clean as it is, might look cluttered if you add ID plates. Nevertheless, high-end ID plates are available from the better yacht and powerboat supply outfits.
  30. plym49
    plym49
    from Earth
    :p
    I guess you drive an automatic. :p
