Hot Rods I want a California Kid driver
Discussion in 'The Hokey Ass Message Board' started by bobwop, Jan 2, 2017.
  1. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    A4B912B1-CF88-4A66-9773-2E8E80932315.jpeg 34493949-2477-4493-B3A4-36E2CDAE43C7.jpeg E17A0790-DC68-432A-8B16-C98B164A78E0.jpeg
    Saw this one and thought of you and this thread, it was s Mecum Auction I believe in Portland last month. It went for $54k I believe. Can’t tell you if it was steel or not, but it was running a 33 Grille Shell. No exposed hinges lead me to believe it’s a glass body as the CKII,
    The CKII had already been sold when I posted it. Keep on looking, how’s your build going? Post some pix....
  2. bobwop
    bobwop
    from Arley, AL
    thanks for the continued interest in the California Kid!
    The body has been completed and is awaiting shipment. We have a REAL 1934 Ford chassis, with title. It was under another hotrod. Ford 9 inch, Small Block Chevy and stick with overdrive. We are contemplating a five speed and going with the new Holley fuel injection setup on the engine.
    The body is obviously fiberglass. Will have cowl vent!
  3. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Looking forward to the build !!!! Hope it has exposed hinges as well as the leaned back posts. BDF2B99C-3248-4B4B-97E3-405F6C47596A.jpeg F1539F9B-900D-407F-A6AA-EB60ABC1C034.jpeg
  4. bobwop
    bobwop
    from Arley, AL
    Yes, stock style hinges and door handles. Same style chop. I was definite about wanting the cowl vent, so no A/C.
    Did go with power windows, but will actuate with window crank.
    swade41, Stogy and 31hotrodguy like this.
  5. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Who’s body did ya chose?
    Stogy likes this.
  6. bobwop
    bobwop
    from Arley, AL
    JPM Hotrods
    Cyclone Kevin, Stogy and HunterYJ like this.
  7. A Boner
    A Boner
    Sounds like you are right on track Bob. Looked at their website.....body looks spot on!
    bobwop likes this.
  8. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Same molds as Gibbon & the Ca Kid Chop.
    #1-Cal Kid In Glendora Day of Purchase 83EF2101-03CE-416C-8E30-2BE545A1D3AB.jpeg
    #2 - Bond - Gibbon Fiberglass Nebraska 068ED320-1E60-4198-8674-8796A284CFA9.jpeg
    #3. & 4. JPM Gibbon Molds Body S.D.
    Do make sure that the latches are exactly in the same location as I’ve noticed that they use bear claw latches and the location is lowered and back on the door. I had a glass body with a stock set of latches and regulators and every detail & a steel structure that a steel body would’ve had. It was heavy......but solid.... miss that one.....:(.
  9. bobwop
    bobwop
    from Arley, AL
    thanks Kevin. We are not going for a spot-on tribute car. But then again, what really was the car? Ford or Chevy engine?
    swade41 and Stogy like this.
  10. belair
    belair
    Good for you, Bob. The only way to get what you want is to get what you want. I still love that 55 Olds you had (several times).
    Thor1 and bobwop like this.
  11. bobwop
    bobwop
    from Arley, AL
    and I have the 55 Olds AGAIN!
    oliver westlund and belair like this.
  12. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Pete’s 34 Coupe before movie fame and into the present is powered by a Ford,
    The magic of the movie world is that since when the hood on the Coupe is initially opened a Windsor engine is exposed for an instant with a unusually long air cleaner.
    Magically in the engine close up it becomes a GM powered 4 carbed hot rod that powers “The California Kid” which John Milner must have sold to Michael McCord in order to avenge his younger brothers death with. I’m sure Milner was done with that one as he “Took them All” @ Paradise Road and would surely build a Hot 327 at Ray’s Automotive to continue his reign as “King of Valley (or maybe it was Michael McCord that sold it to John Milner since The California Kid movie is set in 58 and American Graffiti is set in 62????).;).
    So if you’re building Pete’s Coupe, then, The Windsor, if your building the Movie California Kid prop then either would suffice. ;) :):):)!!!!!!!!
  13. bobwop
    bobwop
    from Arley, AL
    we are going for the "either"
    Chevy small blocks are plentiful, cheap to repair and easy to replace
  14. joeyesmen
    joeyesmen
    I always loved that car too. This is the best pic I have seen of it.
  15. bobwop
    bobwop
    from Arley, AL
    I am leaning towards the red steel wheel look
    Carter, Fordor Ron, Stogy and 2 others like this.
  16. A Boner
    A Boner
    Hopefully the slightly wider rear wheels will have a slightly deeper dish than front wheels.
    (More back space on the front wheels and less back space on the rear wheels)
  17. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
  18. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    D080734F-C505-4C51-A418-1064142BD01B.jpeg How’s the build coming along Bobwop? Hoping during this you’re able to continue on you quest? Here’s another shot of inspiration. ;).
  19. bobwop
    bobwop
    from Arley, AL
    The Kid body is "curing". Chassis is pretty much together. Engine and transmission are in waiting.
    Verno30 is on the job, but ran into a life changing situation with the unexpected passing of his Father.
    I am in no rush.
  20. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Last report was the “Spring Update” The body has had plenty of time to cure so perhaps a “Fall Update” with pix can be done? This is most likely a never before seen shot 4DB23316-AAF2-430E-8B4A-DB5C6071244C.jpeg of the P&J’s Coupes at John Byron’s deuces coming out party back in 81, roughly about the time that Pete got the car back from Cris.
  21. I remember you saying you are 6' 4", Martin sheen is 5' 7"
    Gonna be a tight fit. HRP
    bobwop and Cyclone Kevin like this.
  22. Tim
    Tim
    from KCMO
    I’m 6 ft 220 lbs and can sit in the drivers seat with a toddler on my lap just fine. Cars got great ergonomics
  23. bobwop
    bobwop
    from Arley, AL
    Building it accordingly
  24. bobwop
    bobwop
    from Arley, AL
    We have stalled
    Cyclone Kevin and chryslerfan55 like this.
  25. teach'm
    teach'm
    from Tucson, AZ
    Is that the Lobeck/Coonan/Meyer '32 roadster behind Jake's coupe @Cyclone Kevin?
  26. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Need some Starter Fluid,
    Perhaps a jump start?????
    Maybe a new fusible link?
    bobwop and Stogy like this.
  27. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    I think that it may be P-Woods????????
  28. A Boner
    A Boner
    Stalling isn’t good...get back on it, Bud. Just a couple of hours a week...and it is no longer “stalled”!
    Nicholas Coe and Stogy like this.
  29. Kelly Burns
    Kelly Burns
    Who is Chris, and why did he have Pete's car?
    Stogy likes this.
  30. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Cris Carrier bought Pete’s 34 “The California Kid” about the time “Pete & Jake’s Hot Rod Repair” became a business The “Hair Pair” needed capital in order to get equipment. Several years later Cris offered it up to Pete based on their ”Home of the California Kid” tie in. It was owned by Cris during this photo shoot & SRM Feature in 1977. 83AB440A-0EE9-4353-AD70-2BB7BEF7EB93.jpeg
