I need to find a cheep after market heater for my 49 chev fleet, 53 buick dash, channeled so space is a little tight. Anyone got a cool wrecking yard pull or rv type? I dont want to buy a vintage air at this time, looking for a good idea though, thanks........
Bag one out of ANYTHING that doesn't have air. I'd look at minitrucks first. Get everything from the basic controls to the defogger ducts and diverter outlets under the dash.
I found one I am a fan of. If you can find an old Ford Courier/Mazda pickup, they have a tiny little heater that works very well for its size. Of course it was a little cab. Its dimensions are something like H 15" x W 8" x D 9". Its entirely self contained with the blower, core, everything. It should look pretty much at home in that car.
Mazda Van with rear heat option....cats ass.....complete with controls.!..the whole enchilada is like a giant 8 track...real compact
-------------------------------------------------------------------------- You didn't say whether you need 6 volt or 12 volt fan motor. Most NAPA, Tractor Supply, or similar stores, sell nice compact heaters but now days they prolly only have 12 volt motors. If you need 6 volt, then i have a couple of compact heaters w/6 volt motors out of late 30's early 40's cars, that i would part with. pm me if you want pix.
Late 60's/early70's Dodge pickup uses a small, very compact unit...can be had cheap at nearly any wrecking yard...I put one in a '57 Chevy pick-up...works great. R-
Search EPay collectable parts for an Arvin heater. They were period afer market basically two holes in the firewall for the plumbing/mounting, selfcontained fan and slats and louvres to control the heat. http://i1.ebayimg.com/01/i/05/c2/df/48_1_b.JPG http://cgi.ebay.com/ebaymotors/HOT-ROD-ARVIN-BRAND-HOT-WATER-HEATER-MODEL-74-H-WITH_W0QQitemZ4598892064QQcategoryZ34206QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I buy van suplement heater for $30 comes with switch very small and easy to mount and has high and low speeds.
search heater core on ebay http://search.ebay.com/search/searc...tle=heater+core nearly 500 listings from complete units to bare cores. Get an idea of whats available that way. By the time youve looked at the possibilities, youll know what you want for sure.
Real rods dont have heaters,the warmth of the engine is enough..........well none of the rods ive ever had have had a heater n this is cold England....
I am using an AC evaporator core from a small truck(luv?) with a small fan behind it. My hoodless model A dosen't retain enough heat to heat the firewall anyway. When the temps drop in the 20's I have to partialy block the radiator with a piece of aluminum to get the engine to heat. Sparky
