Cleaning the block I found a void in the oil supply toward the front of the motor. I tried to get a wire through the hole but can't. I'm thinking of making a sleeve to press in and redrill for the cam oil passage . Anyone see this before . Sent from my iPhone using The H.A.M.B. mobile app
It is difficult finding the oil system for the 303 and 324. But the Caddy's of the same era are close to use as a visual. Are you sure a plug isn't what's needed and not a sleeve ? Also, if the cam bearing where not there you would have access to cleaning those oil galleys a lot easier.
The void is toward the water jacket , I'm worried about a pin hole leaking water into my oil supply. I can predrill the cam oil passage or I think there is a passage that leads to the front main. I'm cleaning the block getting ready to assemble the lower end. Sent from my iPhone using The H.A.M.B. mobile app
Maybe you should have the block pressure tested, or figure out a way to do it. That is a real PITA because it's relatively difficult to access.
Can you access the back side from the water jacket side? I havent done this myself, but if you can get at the backside with a thin syringe or something, you can try applying a vacuum to the oil passage side and squirting some wicking grade lock-tite in from the back. I haven't done it myself, but I know someone who ground into some porosity grinding for rod clearance and did this, and I have read about other guys doing this on speedtalk. It will only seal pinholes, but reports are that it will work. I realize pressure testing an olds block is not that easy, but I think that's really what you have to do first. Any fix is complicated and fiddly, so I would make sure that there IS a problem in the first place, before I went looking for a way to fix a problem that might not be a problem.
Goodson seal-all would work too, and cures with heat. You would want to apply a vacuum to the oil side to draw it in, then apply heat.
There's a hole in my vision and comprehension. Missed the word "void". That changes everything. Good thing others read betterer.
I'm going to install the freeze plugs in the side and make plugs for the other holes. Then apply air to see if it leaks. If I have to I can fill the void with expoy and press a sleeve into the oil supply passage. I will most likely do that anyway to eliminate future problems. Sent from my iPhone using The H.A.M.B. mobile app
I also think I'll bring a bore scope home to get a better look from inside the water jacket Sent from my iPhone using The H.A.M.B. mobile app
