I dont know what strait 6 I have -Help!
Discussion in 'The Hokey Ass Message Board' started by MarkKoch, Feb 1, 2010.
  1. MarkKoch
    MarkKoch
    from Maryland
    Ok heres what info I got,Center distributer.Head casting number is 3836848. Gm 28. On passenger side above starter is LAA37I649 and to the left of that 00N1 C183 I have looked through all the casting nymbers for the Gm stove bolts and no matches.The car is a 1948 chevrolet stylemaster.Rochester carb 7003582c Any info will be greatly appriciated tahnks
  2. FatDaddy53
    FatDaddy53
    sounds like a gmc or a chevy truck block..... most likely 235 .... check with the stovebolt forum or the inliners international
    website
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    "C 18 3" sounds like the casting date for the block--March 18, 1953 (since, by 1963, Chevy had discontinued the early six in favor of the 230), and an "848" head came on 1956-62 235s, so it apparently got a later head at some point. Being a '53 block, it can be either a babbit pounder or an insert engine depending on whether it came out of a stick or PG equipped car.
  4. Snarl
    Snarl
    LAA would be a 1953 Passenger car with 3 speed, which should be a babbit pounder. You can tell by looking at the drivers side of the block. There should be a small 3 bolt plate called an oil distribution cover. If you see that, you know you have a babbit pounder.
  5. MarkKoch
    MarkKoch
    from Maryland
    I did and no numbers matching
  6. MarkKoch
    MarkKoch
    from Maryland
    Man,thanks for the info.Im taking notes lol
  7. MarkKoch
    MarkKoch
    from Maryland
    Thanks for the info!
  8. MarkKoch
    MarkKoch
    from Maryland
    Thanks im going to look for the plate your describing tomarrow
  9. MarkKoch
    MarkKoch
    from Maryland
    Yes sir its a babbit pounder,thanks so much for the info
  10. medicinal_marinara
    medicinal_marinara
    from Oregon
    Something doesn't add up here... I thought the 848 head didn't fit on a babbit pounder block. Can you post a picture of the engine?
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It won't bolt to a 216, but it will bolt to a '53 235 of either style.
  12. waldo53
    waldo53
    from ID
    Yep. Chev went to the 18-bolt head with the '53 235's.
  13. Curt B
    Curt B
    Does anybody know if a 18 bolt head will mount on a 15 bolt block or vice versa? I know one hole is a no go but was wondering if the other 14 bolt positions are the same.
  14. Rum Runner
    Rum Runner
    from Fla
    could be a 235 from a pg car that was put in, correct? thus making it a full psi engine?
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The next time I'm in my garage, I'll lay a 216 head gasket over a 235 head gasket and see. In any event, you'd have to fab up a special side cover, as the 216 cover extends up to cover the side of the cylinder head, whereas the 235 cover does not.
  16. Snarl
    Snarl
    Read my earlier post again...
  17. post some pic's of your project.
  18. Curt B
    Curt B
    I ask this to determine if only one additional hole is required in my torque plate for boring/honing older blocks I will add it but if the differences are substantial well then I won’t have time for that. I have one more to make soon and wouldn’t mind seeing it turn into a batch.
    </O:p
    I wish I could find more time to act on a few more tall sidecover designs modeled but only virtually machined.
    <O:p</O:p
    <O:p</O:p
    <O:p</O:p
    I was going to buy gaskets but now I’ll wait for a bit of feedback. Thanks<O:p.
  19. Rum Runner
    Rum Runner
    from Fla
  20. MarkKoch
    MarkKoch
    from Maryland
    I did there in my photo albums,We got snow here(Md) a lot so any more pics are gonna be a while
  21. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Hey, I just laid a 216 head gasket on a '58 235 head, and all of the bolt holes down either side line up. It's the center bolt holes that screw it up.
