hyrdo wont shift past 2nd cold
Discussion in 'The Hokey Ass Message Board' started by petebert, Jul 20, 2008.
  1. petebert
    petebert
    put a low mileage rebuilt dual range hydro behind a 317 y block about a year ago. Works great except it wont shift past 2nd for the first half mile or so. After that the shift points are great. Running Dex/Merc III, I think when I checked its at about the halfway point on the dipstick. I've tried both D3 and D4, same results.
    Maybe top if off? Maybe the fluid hasnt expanded enough when its cold?
  2. 41hemi
    41hemi
    My 400 turbo in my hot rod will act real funny if it is only a half quart low so my vote is to make sure it is right on the full mark. Can't go wrong there.
  3. aerorocket
    aerorocket
    from N.E. P.A.
    Had the same problem with my pontiac powered 55 chevy when My dad And I built it when I was 16. We put more fluid in it after screwing with it for 2 days and it worked fine.
  4. d2_willys
    d2_willys
    from Kansas
    Could be a "sticky" 2-3 valve in valve body. When it warms up it works like it should. I had my 54 Olds valve body cleaned and when the bumpkin at the trans shop reassembled it he forgot to tighten the three screws holding a small plate which leaked enough to have a very sloppy 2-3 shift, so I would think your problem may be valve body related.
    BTW: Lincoln 317.5's are good engines and the hydro works real good behind them, I know having a 54 Lincoln Capri.
  5. badger
    badger
    Top it off for sure, my 54 hydramatic was shifting a tad crappy, after adding half a quart of Dex III to bring her just to the fill line she shifts like a champ, could also be something sticky as d2_willys noted.
  6. petebert
    petebert
    i went to advance auto parts, they no longer carry a bottle with Dex III on the front. Now it says Domestic Vehicle ATF and in little letters it says meets Dex III requirements.
    Is this the stuff to use now?
  7. gridley
    gridley
    Yes that is the stuff that is replacing dex 3. try a bottle of red lube gard. It will help to keep the valves free.
  8. fordf1trucknut
    fordf1trucknut
    I am not sure if that tranny has a vacume modulator but I had a vacume line from the intake to the modulator leak air at first when cold and not allow my tranny to shift till it warmed up. A new vacume line fixed mine.
  9. yorgatron
    yorgatron
    throw a can of Trans-X in there,probably a sticky valve like d2willys said.
