Hot Rods Hydromatic behind a 1950 331 Caddy question
Discussion in 'The Hokey Ass Message Board' started by 2xcrash, Oct 13, 2014.
keep hydraglide
Poll closed Oct 20, 2014.
  1. get an adaptor to chevy auto trans
    1 vote(s)
    100.0%
  2. get an adaptor to go chevy 4/5 manual
    0 vote(s)
    0.0%
  3. get an adaptor to go to earily ford manual
    0 vote(s)
    0.0%
  1. 2xcrash
    2xcrash
    I have a 1950 331 Caddy motor trans combo that I'm putting into a t bucket. When I bought it, it didnt come with the kick down linkage. Am I screwed, do I need it? I'm fairly new with messing with transmissions and am worried I'll jack it up messing with it rather than selling it while it's still in good working order. Should I be looking into spending the 2 grand getting an adaptor and trans to replace the hydramatic( other than having the 3 pedal hot rod rule!). I'm also using a Lokar universal cable shifter, its there something better to use or will this be ok to run.
    Thanks in advance....
  2. oldsman41
    oldsman41
    somebody smarter than me will answer your question, i dont know to much about hydros but whatever you do please post the build.
  3. txturbo
    txturbo
    would be easier and cheaper to get the hydramatic linkage.
  4. JohnEvans
    JohnEvans
    from Phoenix AZ
    You absolutely need the linkage. It controls pressure inside the trans to make it shift right,without it every shift will slip like crazy. Back in the early 60s we would hook up a choke cable to vary the pressure. Full on part throttle shifts would give you whiplash.
  5. falconsprint63
    falconsprint63
    from Mayberry
    you need the linkage, but i vote for 3 pedals. mustang t-5 behind mine
  6. 2xcrash
    2xcrash
    It's behind a 331? What adaptor did you use?
  7. Germ
    Germ
    I would like to know about this 331 Caddy motor with the T-5? Pictures? Measurements of the adapter? Specs?
    Thank you,
    germ
    2xcrash likes this.
  8. GOATROPER02
    GOATROPER02
    from OHIO
    ImageUploadedByH.A.M.B.1413260518.793262.jpg ImageUploadedByH.A.M.B.1413260533.259309.jpg
    We make the early caddy and Olds conversions for T-5/Muncie as well as the 350/400 turbos and 700r4 automatics
  9. 2xcrash
    2xcrash
    Wow, nice work!
  10. Run the Hydro! Build your own linkage and get motorvating.
    Join the Hydro Tech group here and check out the thread B&M Hydro Stick Installation Instructions. It'll give you a pretty good idea on how to build your own kick down linkage.
  11. 40StudeDude
    40StudeDude
    I'm not 100% certain, but I think the 1949-1954 Cadillac 331" engine had the bellhousing built onto it...that would necessitate figuring out how to attach a modern tranny since a modern tranny is manufactured with a bellhousing. You might be in for a big let down IF you don't do any research on the 1950 engine and find out it can't be done...!!!
    R-
  12. GOATROPER02
    GOATROPER02
    from OHIO
    My parts are for extended bell engines.... 49-53/54 caddy
    49-64 olds
    Speedy Canuck likes this.
  13. 40StudeDude
    40StudeDude
    Thanx Goatroper, I can see how you did it now...but does that adapter lengthen the later tranny...???
    R-
  14. steel rebel
    steel rebel
    If you want a stick shift you can get adaptors to put one behind the early '50s Cad. engine. My roadster has an Econoline tranny. with a Jeep shifter. The bottom photo is my Cad. engine adapted to the 48 Ford tranny. Both transmissions are short and work well in T buckets.
  15. GOATROPER02
    GOATROPER02
    from OHIO
    No.... Mine will fit in stock autos without Trans tunnel mods.... Bolts up just like it was a sbc
