Hydraulic Throwout Bearing for early Ford Toploader
Discussion in 'The Hokey Ass Message Board' started by VA HAMB, Feb 8, 2013.
  1. VA HAMB
    VA HAMB
    Im trying to get my new running gear in my car but have hit a raod block!
    Im running an early 283 SBC with an early ford toploader 3 speed and I want to run a hydraulic throwout on it but cant seem to find one anywhere. Does anyone make one for the 1.75 bearing retainer? I could probably rig up a fixture to run a slave on the origional shaft but would rather not do all of that if possible. Any suggestions?
    VA HAMB
  2. ibcalaveras
    ibcalaveras
    Speeway sells one that fits the toploader. Check the spects to see if it will work for u
  3. VA HAMB
    VA HAMB
    I have looked several times and didnt see anything but Ill look again, and then call, maybe they can help me find something. Thanks!
  4. VA HAMB
    VA HAMB
    anyone else?
  5. VA HAMB
    VA HAMB
    I cant find one from Speedway that will fit or from anywhere else for that matter. I set up a slave cylinder on it using the original arm on the clutch shaft but am having troublr getting the slave to push it. Any ideas????
  6. VA HAMB
    VA HAMB
    Nothing? Somebody has to be running a hydraulic on a toploader?
  7. F&J
    F&J
    Can you put up pics of your slave attempt? It can work if the ratios are correct. Like: lever length, slave bore size and master bore size...
    Graham Hood likes this.
  8. oj
    oj
    I think the slave cylinders i have seen 'pull' not push and you use a 5/8 master cylinder. wilwood sells the complete kit.
    when you say 'early ford toploader' do you meany like a '39ish kinda early? i was picturing a 60's era from a mustang.
  9. VA HAMB
    VA HAMB
    Yes a 39ish toploader
  10. VA HAMB
    VA HAMB
  11. bobscogin
    bobscogin
    Would be more helpful if the photo was of the parts that disengage the clutch.
    Bob
  12. mista
    mista
    from Finland
    i'm interested on doing hydraulic cluth on my toploader also.. any help here?
  13. southcross2631
    southcross2631
    1960 Ford pickup I had was a hydraulic clutch from the factory. It worked for years with a 3 speed on the column. That setup or a similar setup should work for you. Used a Mazda pickup slave and master in a dirt track stock that was real slick.
  14. gearhead695456
    gearhead695456
    Interested if you ever got this worked out. I am in the same spot trying to figure out a hydraulic slave cyl on a early 3 speed. Thanks for any photos or specs.........
  15. no55mad
    no55mad
    from nipomo, ca
    There was a recent post concerning hydraulic t.o. bearings and their reliability (bad in my experience). There are pics there of slave cyl applications.
    jjjmm56 and gearhead695456 like this.
  16. earlymopar
    earlymopar
    In most cases, you're better off to use an external hydraulic slave cylinder to actuate a regular clutch arm and release bearing. -EM
    gearhead695456 likes this.
  17. gearhead695456
    gearhead695456
    No55mad, I searched posts to see but only found this one whats it under? Thanks
    Sent from my SM-J700T using The H.A.M.B. mobile app
  18. 36cab
    36cab
    We used a Wilwood external pull slave cylinder to pull one ear on a bell crank that then pushed / turned the equalizer shaft from a second ear. We used the pull slave and an offset bell crank instead of just a push slave as the car is heavily channeled and we did not have room for the push slave to have a straight shot at the equalizer shaft.
  19. 36cab
    36cab
    I found this photo of an external push slave cylinder on a later Ford top-loader. Something similar to this may work for you.
  20. no55mad
    no55mad
    from nipomo, ca
  21. no55mad
    no55mad
    from nipomo, ca
    The above pic was posted in a a thread by bobss396
