Ive asked this before and just looking for info one more time. Putting a Mopar 833 in my truck. The floor is too low to use the clutch fork....so I want to use a hydrualic TO bearing. McLoed and Tilton make them for the 833, but they dont even give you any KY for the price.... I am sure these are probly modified versions of a more common TO bearing. How do you find dimensions of "stock" hydraulic TOBs? How close is close enough? It seems like a little slop is OK, take the self aligning ones for example. Bearing OD for an 833 is 1.250. Let me know!
my mechanic used a place called "quatermaster" thya are some type clutch warehouse they had the correct hyd t/o and dont forget about the bleeding the lines it was my problem they had specials in stock to they may be in the chicago area
