Technical Hydraulic spacer ring kit
Discussion in 'Traditional Hot Rods' started by 303racer, Jun 14, 2020.
  1. 303racer
    303racer
    Just purchased adaptor kit from early v8 garage (excellent quality) just wondering why it doesn't mention welding the ring to the backing plates?
    I'm assuming it's a no brainer, but before i go ahead and lay down a bead. I thought I would ask
  2. irishsteve
    irishsteve
    Looks to me like the four spindle bolts will keep it all in place.Dont over heat the backing plate,and warp it,or you may find the plate rubbing the drum.
  3. alchemy
    alchemy
    You don't need to weld it.
    Desoto291Hemi likes this.
  4. You don't weld it. It is held in by the bolt heads. If you are still concerned contact the Early V8 Garage. That is an interesting piece, all of the ones I have seen before just looked like piston rings.
    Charlie Stephens
    seb fontana likes this.
