Just wondering if someone could shed some light on a slave cylinder question I have. I have a 1994 chevy 5 speed tranny(NV3500 transmission) with the external slave cylinder. I would like to use a internal Hydraulic slave cylinder for my application because of clearance issues. The question I have is, can I use a internal hydraulic slave cylinder from a 1996-thru I think 2000 or 2001 in my 1994 transmission. And where can I find the hydraulic lines. I also have a wilwood clutch master cylinder with a 3/4 bore that I would like to use with this set up. Thanks.......
Call up Summit. I got the hoses and fittings all from them. I jused a stock 1989 T-5 slave cylinder with the speedway clutch master. Works awesome!!
