hurst motor mounts
Discussion in 'The Hokey Ass Message Board' started by jjjmm56, Apr 22, 2013.
  1. jjjmm56
    jjjmm56
    from FL.
    Were can I get good hard rubber mounts for the hurst brackets? My 303 is too heavy for the softer rubber ones.
  2. damagedduck
    damagedduck
    from Greeley Co
    I've heard of guy using rollers for boat trailers for mount rubbers,or even semi truck shock mount rubbers,
  3. CutawayAl
    CutawayAl
    from MI
    If you have what I am thinking of the mounts were early Ford.
  4. V8 Bob
    V8 Bob
    Chassis Engineering Inc. sells the best quality Ford style biscuit mount I've seen so far.
  5. 3banjos
    3banjos
    from NZ
    Original flathead style work great. With the cupped retainer/washer. Holds rubber mount in shape.
  6. Marty Strode
    Marty Strode
    V8 Bob is right ,Chassis Engineering sells the best ones I have found. Another great feature about their mounts is they use a standard 7/16 bolt, instead of the shouldered large head OEM type, that can come in handy if you should need to elevate the engine. You can install a spacer between the pad and the mount, and install a proper length bolt.
  7. Hackerbilt
    Hackerbilt
    I don't know if they are all made with the same inferior rubber or not, but I used boat roller sections as bodymounts on a vehicle and they needed replacing in LESS than a year!
    Split and crumbled badly due to UV rays I assume. (The mounts were at the body edge)
    You would figure something designed(?) for full time exposure to the sun wouldn't have that problem.
    Then again, they may not all be low quality like that.
  8. fab32
    fab32
    Can't forget about the old stand by..........hockey pucks:D
    Frank
  9. 1949SilverStreak
    1949SilverStreak
    from Canada
    Was just going to say that.
    I'm using a pair of biscuit style mounts I bought from So-Cal with my Hurst front mount.
  10. CGkidd
    CGkidd
    Anyone know if there is any companies making them out of urethane like the grant mounts
    Sent from my DROID device using the TJJ mobile app
