hey guys, i'm in the process of rebuilding my front suspension on my 51 Ford Victoria, and removed what i thought was an old time custom fabbed dropped drag link to clear my SBC oil pan...well i cleaned all the grime off of it, in preparation to cut the worn steering knuckle off of it and weld on a new one i cut from a new drag link i bought, and the dropped sections of the drag link have Hurst stamped into them....at first i thought someone made the drop from an old Hurst engine mount or something, but Hurst is stamped on both ends and both sides of the link, perfectly centered... i thought that was cool as hell, since i never knew any such thing was actually manufactured...so, i guess i'm just looking for someone to confirm that Hurst made these and about when (my first guess is mid 60's), but I'd like to know for sure...THANKS, BOB
Seems like I remember seeing these in old magazine ads...Plus I remember an old how-to in an early mag,showing some of the roughest looking cuts and welds I've ever seen...EDIT....the bad looking piece was NOT the Hurst piece,it was the "home-made" one
a friend of mine had one on his 55 chevy...i think left over from an earlier 409 install with deep sump pan.
I've also got one hanging on the wall that was on a 55 Chevy with a 348/409. Nice item that solved a lot of problems. Max
. . remember Hurst advertising these in very early '60s . . . . only remember two(my memory is getting worse), one for '49-'51 Fords, and one for '52-'53 Fords; probably still have the advertising around somewhere. They did work, would think they'd still be available today, except for the Fat Man and Mustang II rack and pinion route people generally take today. My dad made a homemade one by welding the squatty 'U' to stock drag link, and then cutting out the center between the knuckles . . . . saw a N.O.S. '52-'53 model for sale on e-Bay a while back . . . . don't think it ever sold . . . . would like to get hold of the earlier '49-'51 model . . . there's got to be some rat-holed somewhere . . . Joe Doaks
I have one of the Hurst dropped centerlinks on my 57 too and like you when I first saw it I thought it was some shadetree engineering but it apparently is a store-bought piece with some nice welding.
A dropped center link came with my '49 Coupe in a box of parts. It was pretty grungy and I too thought it was a home made piece so I just stuck it on a shelf. A few years later I decided to clean it up and found that it was stamped HURST in a couple places. It had been painted red at one time, but Im not sure if they originally came that way.
Bob.... Do you still have the dropped center link for the Shoebox.... Im in need if you have it and want to sell..... Redoin the steerin in my Kustom. Rich King (aka Rags) boonton nj This is what Im lookin for.....
I believe they were made for some of the mid 60's chevies too.. Seen one in a 64' and it was painted red can't verify that it was actually a hurst..
Snopeks..... Your makin me feel a little dumb here."Drop Blocks" can you explain further.. Im a little confused... I have been fooling around with shoebox fords for years and have always used dropped center links to get the clearance that I needed when installing a SBC . Rich aka Rags
http://www.droppedaxles.com/FORD_AXLES.html#TXTOBJ7D8B5731291381 There on the bottom of the page. I used them on my f-100. It lowered my drag link 2in. Also speedway makes a lowered ball joint that drops the drag link 1 1/2 in .
These appear to work with a Straight axle truck steering.... Dont think that they will work with Shoebox independent suspension Rags To Richs
