Technical hub cap removal
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 31, 2015.
  1. Ron Brown
    Ron Brown
    anyone have a trick for pulling the hubcaps of Kelsey Hayes style 16" wires without scratching or damaging the paint on the wheel? Only way I can see is just cover screwdriver tip with tape. image.jpg
    Model T1 likes this.
  2. 2935ford
    2935ford
    That's how I take mine off.....just go slow and easy.......I usually manage to chip some paint. Seems sometimes, powder coated holds up better.
  3. Ron Brown
    Ron Brown
    luckily they are powdercoated for about 6mos so they should be cured about as hard as it gets...gotta pull the front wheels in the morning so I will find out then
  4. 2935ford
    2935ford
  5. I use an oak wedge with a small hammer.
  6. flthd31
    flthd31
    I've had good luck with this poly/nylon composite, trim and molding tool set from Harbor Freight. They're pretty tough and cheap of course.
    MAD 034, i.rant and lothiandon1940 like this.
  7. I use a old credit card.
    timwhit likes this.
  8. Hnstray
    Hnstray
    from Quincy, IL
    Once you get them off, consider drilling a couple of small holes, fairly close together, in the edge near the rim. Fabricate a 'puller' from piano wire (stiffer the better wire) with a loop for your fingers and 'hooks' that fit in the holes. I don't recall where, but I have seen some oem small caps like that.
    Ray
  9. lewk
    lewk
    from Mt
    VW bugs and buses had that. Maybe you could even find one of the VW tools.
  10. I have always been able to pop the hub cap on my old bent spoke kelseys with a silver dollar I keep in my pocket that my granddad gave me when I was a kid.
    Works great. HRP
    catdad49 and lothiandon1940 like this.
  11. I use a small plastic ice scrapper. I think it was a firestone promo. Works great, just used it today. I will post a photo of it soon.
  12. 28TUDOR
    28TUDOR
    Slide hammer with a hook attachment will pop it right off.
  13. I've been lucky enough to pull them off with my fingers but it's a grunt
  14. I use a composite wedge-shaped tool made for installing windshields with rubber over the pinch weld...works pretty good. I've also used a nice clean putty knife and go slow...have to tap it in and slowly pry out on it..
    lothiandon1940 likes this.
  15. Ron Brown
    Ron Brown
    thanks for the suggestions...used one of my wife's plastic spatulas...Ha. nary a scratch and she hasn't missed it........so far
    life is good. Ron
    catdad49, flyin-t and lothiandon1940 like this.
  16. ........................Just wait until you ask her to make pancakes again.:D
  17. Drive'em
    Drive'em
    Ok, this sounds stupid, but I use a popsicle stick. I take a utility knife and slice it thin on the flat side. I just push it under the cap till the cap raises up a bit, then I use the unsliced end, then my fingers. Works for me!
  18. 2935ford
    2935ford
  19. What Flavor?:rolleyes:
  20. 41 C28
    41 C28
    This is what I use, a VW hub cap puller. Requires two small holes in hub cap edge.
      119.7 KB
  21. I just go really fast around a corner
  22. choptop40
    choptop40
    That's funny...
  23. big duece
    big duece
    from kansas
    That's a good looking A sedan!
  24. 19Fordy
    19Fordy
    I use a plastic Bondo spreader at several places around the perimeter of the hubcap.
    The cap gradually raises up and pops off.
