hub bearing to spindle seal ?
Discussion in 'The Hokey Ass Message Board' started by supercab78, Mar 18, 2013.
  1. supercab78
    supercab78
    I'm using what I believe to be F1 spindles and f100 hubs and drums. The diameter of the seal surface is 1.75 inch. All I can find local is still listed as leather seals. Upon searching on here all the recommended seals are for 1.5 or 1.562 surfaces. Any ideas?
  2. BOBCRMAN
    BOBCRMAN
    from Holly
    Find a real auto parts or industrial supply and in their catalogs will be the specs you need. OD-ID-material
    www.applied.com/
  3. 27troadster
    27troadster
  4. supercab78
    supercab78
    BOBCRMAN; When on the site "applied.com", and inputting dimensions on the shaft size do you think I should plug in 1 5/8 inch for a actual size of 1 3/4 inch seal surface? Or do they make them smaller to seal the shaft size that is inputted?
  5. manyolcars
    manyolcars
  6. supercab78
    supercab78
    I think the diameter of the seal surface is smaller on 40 spindles. I could be wrong as this is my first time around at this. I used the www.applied.com site and have some on order. I'll post the result when they come in. Thanks
  7. JohnEvans
    JohnEvans
    from Phoenix AZ
    As I recall the front wheel seal is the same 28-48 !!!
  8. If you have F-1 spindles (1-3/4" seal surface) and F-100 hubs, just get a stock F-1 or F-100 seal, they are the same part, Timken 5827. There is nothing wrong with using leather wheel seals either.
  9. supercab78
    supercab78
    RICH B; Isn't the reason for the grease cups was to catch and redirect the grease that would leak past them? Or are the new leather seals better then the old ones?
  10. I think modern wheel bearing grease is more heat resistant and stays "in" better. I still install the grease shields tho.
