Technical How to split a 9" traction lock
Discussion in 'The Hokey Ass Message Board' started by flatheadfever, Apr 17, 2015.
  1. image.jpg what do I need to do to separate the two halves?
    I remove the two screws
  2. theHIGHLANDER
    theHIGHLANDER
    Does this help?
    shagged from a google image search...
  3. squirrel
  4. gregga
    gregga
    First in the series. I followed this and ended up with a perfect pattern first try.
  5. A dead blow hammer and wrap it on the end you have sticking up in several directions that should loosen it up. Then just worry it apart. That is how I get 'em apart.
  6. squirrel
    I didn't read the manual again, I just posted the link, but I figured the roll pin was probably most of what was holding it together. It's been 25 or so years since I worked on one.
    270dodge likes this.
