Hopefully some one can help me remove my side window on my 1955 dodge royal. i have no idea how it comes out. its not the window in the door its the one in the back seat area on a two door. any help would be helpful thanks.
is it a hardtop or sedan? I think you'll find the regulator has 3/8 inch pins that go thru the bottom channel of the glass. it might help if you take a small mirror to look at the round spring clips on the back side that lock in a groove on those pins. some clips have a key hole that slide on and off. the other type have four barbs that snap on and need to be pried off. let me know if you need more information
You need to remove the rear seat & the interior side panel. Then you can get at everything to unfasten it and pull it out. It is not hard.
