How to clean tools after fire?
Discussion in 'The Hokey Ass Message Board' started by troneew, Mar 23, 2011.
  1. troneew
    troneew
    from Georgia
    I have been digging some of my tools out of the ruins of my shop after a fire from several months ago. Does anyone have any suggestions for trying to clean the crud like rust and fire residue and who knows what else off of them? They are mostly hand tools and sockets and tire tools and things like that. Thanks.
  2. iamspencer
    iamspencer
    I would soak in kerosene
  3. phat rat
    phat rat
    The ones that are not usable can be turned in for new if they are Craftsman and I think SK also. Wouldn't hurt to check out the other brands guarantee also
  4. Halfdozen
    Halfdozen
    Oven cleaner.
  5. Destralo Roach
    Destralo Roach
    Wire brush on a grinder motor, and then oil, but if they are that bad they are probably soft and wont be usable, sorta like the cheapest Chinese tools out there.....Roach.
  6. Get an old dryer and put it out back. Throw the tools and some abrasive in it. Set it on cool and let her run........
  7. thepolecat
    thepolecat
    1. S.F.C.C.
    almost every hand tool has a guarantee to be replaced if damaged- go try and turn them in.
  8. Dane
    Dane
    from Soquel, CA
  9. Willy301
    Willy301
    as long as most of the heat was indirect they probably are still useable, I have seen tractors restored after direct flame contact without too big of a problem. The other thing is how hot did it get, if it was fully engulfed and burnt to the ground there would be more heat, but if the only part of the structure burnt then it was not nearly as hot. I hope you had insurance, not sure how good the tool warranty programs are for tools damaged by fire as opposed to breaking under heavy use... good luck, sorry for your loss.
  10. moparmonkey
    moparmonkey
    from NorCal
    Oven cleaner will take all the junk off. Use some oil for the rust.
    If there's significant flash rust, that indicates the tools got hot, possibly hot enough to change the temper. Most of the time, this isn't the case though. The tools pretty much have to glow red hot to change the temper, flame contact alone won't do it.
  11. Swifster
    Swifster
    Any reason why your homeowners insurance didn't cover these?
  12. tommy
    tommy
    I have some that were in a garage fire 35 years ago. They are still blue/black. Most of the bigger sockets lost their temper and simply stripped the flats out when we tried to open up an engine with a breaker bar to see how bad it was inside. I have some 1/4" drive sockets that still work ok. Not much torque required for those sizes. I could push the valve springs down with my fingers on a 396. I don't think you will ever make them look good again. The chrome blues just like a Harley exhaust pipe.
  13. Try Citriclean it's a citrus based cleaner works great. I work in oil and gas and deal with some pretty nasty crap and this removes most anything. Smells nice too.
  14. The all steel items could go in the engine vat. Castrol superclean will take smoke off.
  15. Snickern
    Snickern
    from Norway
    I lost most of my tools in a fire 15 yrs ago, still have some of it for use. I wirebrushed it, an painted dem with cheap spray paint, you find out fast witch fits the garbage bin, and witch you still can use. I had a lot of kamaza and teng tools (good quality) still have those, but the cheap stuff, like HF in usa is not worth anything after a fire. Dont think you will get dem nice again, so my tip is spray can paint. Good luck
  16. 123
    123
    from Seattle
    If you can't exchange them for new ones try Evaporust from Harbor freight. I used it on some old rusty sockets and it cleaned them right up. It wont hurt the rubber or plastic on th handles either.
  17. 1971BB427
    1971BB427
    from Oregon
    If the tool boxes they were in didn't get hot enough to sag or distort, then the tools will be fine. Just soak them in Kroil or kerosene and then wipe them off.
  18. bryan6902
    bryan6902
    Just clean the big chunks of nastiness and grit off and use them as is. I bet most of the stuff will wear off with use. If the temper is gone, most of them will hit the trash soon enough so why bother with a whole lot of cleaning....
