Here’s what you do aces. When replying to a post, just tap the plus button next to the subject line. It will then bring up a tool bar with various icons on it. To add a photo tap the portrait icon. This will open up your photo library, then just tap the picture you want to add and it will do it automatically. After that you can add text if want to. Sent from my iPhone using H.A.M.B.
When you hit the reply ( left pointing arrow on the bottom right of your screen) symbol, do you get little icons on the bottom of the message?
On my phone where I'm typing this, I have a circle with an upside down "V" in it. If I hit that, I have the keyboard at the bottom and just above that, a bar with icons in it. The icons look like a camera, a rectangle with a "mountain" in it, a smiley face, and a paperclip. If you have those things, you can hit them and see what comes up. That's what I use to add pics. The hardest part is once I see the pictures on my phone, is finding the one I want to add.
Aces, does it look like this? If it does you just click on upload a file then it will as you from where usually like documents or gallery click on that go through your pics till you find the right one and click on it then you usually are asked thumbnail or full size. Hope that helps.
I use upload a file at bottom near post and go to the folder pic and once it loads select full image... This post should be in questions and suggestions. Not bitchen just saying. Little learning curves...still don't know it all either @aces52 There is tutorials as well about pic posting...
