How to achieve a cast finish?
Discussion in 'The Hokey Ass Message Board' started by No_Respect, Feb 2, 2011.
  1. No_Respect
    No_Respect
    from So-Cal
    I have a bunch of billet machined parts that were one off made. I do not want to polish these parts is there a way to achieve a cast look on these?
  2. media blast
    kidcampbell71 likes this.
  3. Da Tinman
    Da Tinman
  4. shane85
    shane85
    glass bead media.
  5. Deuces
    Deuces
    Nope! Bird shot!
  6. No_Respect
    No_Respect
    from So-Cal
    Wow thanks guys! I was told that Media wont work so I guess I'll try it out!
  7. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    File edges, shot peen then sand blast.
  8. Da Tinman
    Da Tinman
    actually heavy grit sand works much better, tried both and sand is much more convincing.
  9. Crafty B
    Crafty B
    steel shot in a sandblast cabinet then lightly scotchbrite...I do it everyday
    CB
    61klassic likes this.
  10. treb11
    treb11
    the bigger the grit, the rougher the fiinish will be. So skip the glass beads and go straight for playground sand
  11. handyandy289
    handyandy289
    from Georgia
    Try a pneumatic de-scaler. the one with a bunch of rods for chipping scale or rust.
  12. yekoms
    yekoms
    I'm a cylinder head guy in a race engine shop. Garnet media in a blaster works great for making machined steel or cast iron look as cast. On softer metals back blaster nozzle away from part. If you want a section of your part to not get texured tape it off with heavy rubber tape. The tape that powder coaters use should work. Duct tape just gets shredded to a gooey mess. You can even file in small grooves to make fake casting seams.
    On soft metals sand like Da Tinman said works good.
    Smokey
  13. CutawayAl
    CutawayAl
    from MI
    A needle scaler works, but it's slow, tedious, and requires some practice/skill to get a good result. I found you get a better look by contouring all the needles to look like a sharpened pencil, but with the points radiused round. At the same time, all the needles should be kept the same length. Over time, and depending on the material of the parts, the needles will require re-radiusing.
    Blasting with sand, grit, etc. will produce a rough satin finish, but careful blasting with appropriate sized shot or large diameter glass beads(on aluminum) produces a finish more like a casting.
    Be aware that overly heavy blasting imparts a lot of stress into the part. That can cause distortion, and even break small parts. To avoid problems, especially on thin/delicate parts; all you want to do is alter the surface using as little pressure as possible/practical, nothing more.
    Whether blasting or needling is done, on aluminum I have found that a light final finishing with fine Scotch-Brite and phosphoric acid(Alumi-Prep or aluminum cleaner) rounds off the worst of the surface roughness, giving a nicer finish that is easier to keep clean and less susceptible to fingerprints etc.
  14. pecker head
    pecker head
    What is the differents between machined aluminum & billet ?
  15. Skirv
    Skirv
    I did this to a few parts including this water neck. I softened the sharp edges with a grinder, went over the parts with a needle scaler, then sand blasted.
  16. The word billet is used incorrectly most of the time.
  17. pecker head
    pecker head
  18. CutawayAl
    CutawayAl
    from MI
    The definition varies a little from one field to another. Foundries call rough poured blocks of metal billets. The forging industry calls raw forgings billets. In the hot rod crowd, in the minds of most, billet is the fully machined, machined from solid look. In the automotive world, a forging is a forging, a casting is a casting, and a billet part is one machined from a solid chunk(billet) of material. For example, billet gears, crankshafts, connecting rods, and cylinder blocks are carved/machined from a solid block of raw material. Although a casting can be fully machined to look like a billet part, in automotive terms it really isn't billet, it is a fully machined casting.
  19. pecker head
    pecker head
  20. No_Respect
    No_Respect
    from So-Cal
    Lots of good info here I have a modern billet Aluminum head that I want to make look like its cast and the intake which was custom machined for me. I just want to make the modern engine look like it was stock from the 1960's
  21. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    If doing just some touch up on freshly machined, or welded sections of a cast part, I just grab a piece of sandpaper, and hammer some texture into the surface. You can vary the roughness with different grits!
    tomkelly88 likes this.
  22. Deuces
    Deuces
  23. scootermcrad
    scootermcrad
    Was just thinking about this very topic...
    Now THAT is an interesting approach! Probably works well on aluminum...
  24. RHOPPER
    RHOPPER
    Round the edges and spray with hammertone paint?
  25. von Dyck
    von Dyck
    Well, if you are going to paint the part, after correct prepping, spray on your "tack" coat. Sprinkle some clean sand (your choice of grit) and follow up with subsequent coats for complete coverage. Works great where a cast iron or aluminum repair was made and the part was originally painted.
  26. Da Tinman
    Da Tinman
    Fresh out of the blast cabinet, sprayed with flat clear. Knocked most of the street rod right out of it, they was brushed when I got em.
    makes them almost invisible when installed. I made new brackets to mount them upright and those arent the correct screws.
  27. Larry T
    Larry T
  28. jcs64
    jcs64
    these started off as 6.5" dia. carbon bar stock Before I machined them.
    Just grind and file all the sharp corners (irregularly makes for a more casted look), Then media blast. I used glass, but a coarser sand would have worked better
    Jeff
  29. xlr8
    xlr8
    from Idaho
    Eastwood and some of the other restoration suppliers make a paint that gives the cast look.
