Ok, what , how to size my 34 ford door hinges prior to paint? I'd really like to prevent the chipping.....
Beval the adjoining area where the hinge pin goes. It keeps from poping the paint when opening and closeing the door.
Nope, it's HRP's secret and he's not sharing. On stuff I've painted with hinges (not car doors) I've taped off the hinges prior to painting so they wouldn't get a thick coat of paint, then gone back and brush painted a thin coat to prevent interference. Just a thought.
Thanks guys, I see my first mistake was to not put the pins in first and then mount the doors to the body.....you see, I've taken the doors off a lot lately on the 33 and I'm chipping the paint by simply knocking out the pins.....and with no help...
just thinking here but, if ya ground down (or filed) the areas that rub, the parts that surround the hinge pin. and installed nylon washers the same thickness and diameter that you ground down. then disassemble the hinges, paint them reassemble with the nylon washers. then the only metal to metal contact would be where they bolt onto the door and body right? no more chipping.
Light thin paint is the best advice I can give. Qas you prime and paint the car you end up with thick paint on the bottom of each hinge loop, after prime, seal, paint its very thick. So derust your hinges well, dust coat with prime and make topcoat passes that are very light until covered.
