I took 4 new coker firestones up to get mounted today. both fronts 6.00-16 balanced out at 2 and 3 ounces one back 7.50-16 took 2.5 ounce the other was 11.75 ounces. we moved the tire around several places on the rim made no difference. my question is how much weight can you put on a rim before the tire is considered defective. 11.75 ounces looks ugly on back side of rim and is way more than I've ever seen on a rim
That is a lot. Were the wheels new to you also or were they ones you had used before and not part of the problem? Can you contact the seller or manufacturer rep. to see what they are willing to do about it?
The weight is not the worst thing, let them run on the balancer and see if they are also out of round. You will see the tread wobble up and down... I had a few 560-15 cokers I had to shave to get them round... car had a terrible wobble ab 50-65 mph.
Can you start off by seeing if the bare wheels will balance, they might be way off. If not I would say it is the tires.
He said he moved the tire around on the wheel with no difference, so it's not the wheel. You got to read what the OP posts before replying.
You can not rule out the wheel unless you tried a different wheel and still had a balance problem....Moving the same tire on same wheel same problem, does not eliminate one...
11 oz is way too much weight to put on any wheel. This much wheel weight will cause other problems if not corrected. If you bought tires new from Coker, or a dealer, you should call them and request an exchange. The tire itself sounds to be out of round.
Diamond back tire ,no problem ever and 11 is too much. If you move the tire around on the rim and the point of off balance moves with it then it's got to be the tire,right?.
If you want to run bias ply tires, there's not a lot of choices out there.. I don't think you're ever going to get bias plies to run as smooth as radials but who wants radials on a hot rod..
I had problems with my Coker Radials being way out of round. They would balance but were so out of round you could really feel it going down the road. To be fair I contacted Coker and once I had them road force balanced they replaced them at a prorated cost. I think your best bet will be to get them road force balanced to see what is really going on with the tires.
This is a risk for anyone wanting to run these tires. I have sent back a pair before. They didn't hassle me, but by the time you pay shipping and re-mount fees. . . Sent from my iPhone using H.A.M.B.
^^^ IMHO, If Coker insists on shipping out/selling out of round or out of balance tires (because of their production errors and poor QC practices), they should pick up the shipping both ways on the return. 11 oz. is WAY too much. That's nearly 3/4 of a pound!
I had one of my Coker Bias look radials that couldn't be balanced on my wire wheels. The guy told me that the wheel was so out of round he couldn't get it to balance correctly. I bought him a different wheel and he mounted and balanced the tire with no problem. These were 34 wire wheels I had bought used. Three of the four were good but that last one was not.
FWIW last summer I purchased the 4 Firestone's shown on my avatar Lincoln from Coker. I mounted and trued them and found them to be acceptably round. I shaved very little rubber off of them. The stock rims are surprisingly true as well. Very little weight was required to balance.
When I was mounting tires, a new tire with 6 oz was a lot and borderline, but some coopers did take 6 and ran ok. 11 oz is way to much. I do like the idea to spin it on the balancer and see if it is out of round.
i'm not going to rule out the wheel. before I get a hold of coker I want to try another wheel I know there going to want to blame it on the wheel. problem is I don't have another wheel. if anybody has one they would be willing to sell i'm buying. 16x4.5 with 4.5 bolt pattern, early mopar maybe truck wheel. I have the 4inch wide car rims on front they are easy to find
I'm on my 5 set of Coker bias ply tires and used one set of their radial whitewalls,Bias ply tires generally take more weight and are never perfect,the Firestone molds are ancient. If you want your car to ride like a new car use Diamondback radials. HRP
