How much does your T or A weigh?
Discussion in 'The Hokey Ass Message Board' started by J Man, Jul 9, 2009.
  1. J Man
    J Man
    from Angola, IN
    The lighter rod you have and the more power you have makes for a faster car (common sense). So who out there actually knows the weight of their car and takes the weight into consideration when building their car?
  2. I weighted my roadster with me in it and it was 2100 lbs. with me in it and I am 180lbs
    also my sedan weights 2400
  3. at this point the A is about 220# and the T 280#. seriously built the flamed A in the 80's with a 427 and it scaled 2450#.
  4. 61bone
    61bone
    My T coupe scales at 2230
  5. Craig Owens
    Craig Owens
    I weighed my 30 Model A coupe on a Bekins Moving Co. certified scale, and it weighed 2480 pounds. Since then, I've added aluminum door panels, some sound deadener in the floor and a rubber floor mat, so it's safe to call it an even 2500 pounds. This was with a full tank of gas (16 gallons), but no one in the car. In the build process, I kept it in mind to add no un-necessary weight, so without taking extra measures to go light (ie: no floors or just partial floors, no glass, aluminum heads, etc), I don't know how you'd cut that weight by much.
    Craig
  6. Defisch
    Defisch
    from Hudson FL.
    Mine weighs 2140 with a flatty.
  7. Dad's A weighs 2200lbs 302W powered.
  8. My 29 Roadster weighs in at 2340 lbs. It's fiberglass and I was surprised at the number, but you really don't save any weight with a glass car because of the steel reinforcing and I went a little overboard on the steel in mine. Small block Chevy and TH350. Rated at 275 HP. Plenty strong enough for an old guy!!:eek:
  9. Speedsterinc
    Speedsterinc
    The Lil Truck weights 1708.
  10. srosa707
    srosa707
    from Sacramento
    Mine weighs just at 2300.
  11. gas pumper
    gas pumper
    My T is 1740lbs on a junkyard scale without me and with 5 gal gas. The guy at the yard says the scale is right. 283 T-5 glass bucket. No frills.
  12. langy
    langy
    My T weighs in at 1660lbs, I have 330bhp :D
  13. Roadsterpu
    Roadsterpu
    29 RPU with a small block 2140 pounds
  14. My glass T weighs 1840 with 960 on the front and 880 on the rear without me in it, 80 lbs. off 50/50, with my 230 lb. ass in it probably rear heavy. Power to weight is great but it doesn't hook worth a shit.
  15. flatheadpete
    flatheadpete
    from Burton, MI
    The Peter Beater weighed 1460 w/Flatty and 5 speed and a half tank gas.
  16. Model A John
    Model A John
    from wichita ks
    My '31 A coupe weighs 2300 lbs. without driver. Fenderless, SBC, steel wheels, unfinished interior, 9" rear, 2x3 frame.
  17. hollywood 423
    hollywood 423
    from west ohio
    My 28 coupester with no fenders and banger power was 2000 even on the elevator scales last week..
  18. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
    My A sedan weighed 2560,full fender.
  19. pasadenahotrod
    pasadenahotrod
    from Texas
    My old T Roadster weighs 1750# wet with no one aboard. 283/alum. PG/57 Chevy rear/CAE sprint car front end/56 Pickup steering/ 40 brakes up front/CalAuto glass body.
  20. BBobb
    BBobb
    I am at 2460 lbs with my fat ass sitting in her
  21. 2002p51
    2002p51
    1,941 pounds. Glass body, steel hood, 8BA with C4 trans.
    Weighed on a set of those electronic race scales.
