OK guys, living in the land of (don't have and can't get) I need the approx. weight of each front wheel of my fenderless 29 Pk Up. Only scale I can dig up is one of those electronic jobs and it won't do it. I'm running a AMC 4 banger/5sp and every thing is pretty much standard. Need this info to get the coilovers sized. Any help would be appreachated. Ice man
Think outside the box. There is a way to use a standard bathroom scale and a 2X4 to get the weight divided to within the scale's range, but you might be able to find a road race/circle track guy with scales, a truck scale (do they require on the road trucks to be within limits there?), of an agricultural scale that will work. http://forums.corral.net/forums/showthread.php?p=7574061
As I said at the beginning, DON"T HAVE CAN"T GET. They don't weigh trucks here, except at the cement plant, and I can't drive there yet. No inspection. Scales are not an important thing here. If the truck has room, it can't be overloaded, put some more in. I weighed my roadster at the cement plant when it was built, but it needed to be registered, the truck has that. O well ill try some thing else. Ice man
Ice man, I ASKED if you had access to truck scales, I didn't assume. Did you follow the link I provided?
Do you have a Airport there? What about at a hanger where they do aircraft inspections.. They usually have calibrated scales for the Smaller airplanes. 4 of those scales would work.. they would be no higher than car ramps.. Or a shipping dock.. they have to weigh in for transport of goods.. does that help??
If it was legal to drive on the road I could use any number of places with scales, but its not legal yet. So I'm still bound to my shop. Ice man
I saved this from another site a while ago hope this helps<TABLE cellSpacing=0 cellPadding=6 width="100%" border=0><TBODY><TR><TD class=alt2 style="BORDER-RIGHT: 1px inset; BORDER-TOP: 1px inset; BORDER-LEFT: 1px inset; BORDER-BOTTOM: 1px inset">Originally Posted by Beenaway2long 4 pieces of copy paper and an accurate tire pressure guage. Cheapest easiest way. (no, I haven't sniffed too much nitrous) On a flat surface, slide a sheet of paper behind, in front of and on both sides of a tire. Measure the distance front/aft & side to side. Multiply width by length, for total square inches of tire footprint. Check tire pressure. Multiply psi x the square inches. Do the same for the remaining tires. Add thewm together. and you have your weight. I was within 8# on a 2700# race car, and a 3100# 65 chevelle. Slide the paper in until it stops, and keep them parallel /square. </TD></TR></TBODY></TABLE>
