ordered this cam for the J, how much carb do you think I'll need to feed it?? <table border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"><td class="overview-c1" width="25%">Brand:</td><td class="overview-c2" width="75%">Lunati</td></tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"><td class="overview-c1" width="25%">Product Line:</td><td class="overview-c2" width="75%">Lunati Bracket Master II Cam and Lifter Kits</td></tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"><td class="overview-c1" width="25%">Part Type:</td><td class="overview-c2" width="75%">Camshaft and Lifter Kits</td></tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Cam Style:</td> <td class="overview-c2" width="75%">Hydraulic flat tappet</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Basic Operating RPM Range:</td> <td class="overview-c2" width="75%">2,000-6,000</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Intake Duration at 050 inch Lift:</td> <td class="overview-c2" width="75%">230</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Exhaust Duration at 050 inch Lift:</td> <td class="overview-c2" width="75%">230</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Duration at 050 inch Lift:</td> <td class="overview-c2" width="75%">230 int./230 exh.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Advertised Intake Duration:</td> <td class="overview-c2" width="75%">292</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Advertised Exhaust Duration:</td> <td class="overview-c2" width="75%">292</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Advertised Duration:</td> <td class="overview-c2" width="75%">292 int./292 exh.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Intake Valve Lift with Factory Rocker Arm Ratio:</td> <td class="overview-c2" width="75%">0.512 in.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Exhaust Valve Lift with Factory Rocker Arm Ratio:</td> <td class="overview-c2" width="75%">0.512 in.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Valve Lift with Factory Rocker Arm Ratio:</td> <td class="overview-c2" width="75%">0.512 int./0.512 exh. lift</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Lobe Separation (degrees):</td> <td class="overview-c2" width="75%">110</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Intake Valve Lash:</td> <td class="overview-c2" width="75%">0.000 in.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Exhaust Valve Lash:</td> <td class="overview-c2" width="75%">0.000 in.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Computer Controlled Compatible:</td> <td class="overview-c2" width="75%">No</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Lifters Included:</td> <td class="overview-c2" width="75%">Yes</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5';" onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Lifter Style:</td> <td class="overview-c2" width="75%">Hydraulic flat tappet</td></tr></tbody></table>
Well, assuming you're leaving the rest of it stock and just adding what should be a real lumpy cam, headers?? I would do a dual plane intake and probably no more than a 600cfm carb. I like Edelbrock carbs for the simple reason of basically out of the box and on the car and down the road. If it runs rich you just change the internal springs and likewise if it's too lean.600 should flow plenty of air for the 289. That said if you run headers, run a 2 1/4 in. exhaust for max. flow but no more than that.
Holley 650 should be plenty, had good luck with one on a built 351W H.O. I did. Dual plane or Edelbrock Torquer style intake with that RPM range for a cam, Weiand has a nice dual plane high rise these days. And, just a little trick, if it doesen't come with it, cut a little notch out of the split if you get a dual plane about 2" by 1" or so is usually good and do it towards the secondary side, this really helps on the higher RPM and we all know 289s like to rev.
