How many threads should be showing on a lugnut?
Discussion in 'The Hokey Ass Message Board' started by evintho, Jul 31, 2013.
  1. evintho
    evintho
    Basic question. The wheels are torqued down and barely two threads are showing. Is that enough?
  2. Rusty O'Toole
    Rusty O'Toole
    Looks ok to me. As long as all threads are engaged (bolt extends the full length of the nut) you have full strength.
    I would be more concerned that the wheel is not fully seated and the center hole is not centered on anything.
  3. Jimm56
    Jimm56
    Is there a spacer in there?
  4. belair
    belair
    All the threads of the bolt are engaged-what else is there?
  5. Kramer
    Kramer
    I'm wondering about a spacer also. It does not look like the wheel is fully seated.
  6. Greaser Bob
    Greaser Bob
    Just enough to get to the chewy center!
  7. evintho
    evintho
    Thanks guys! Yeah, it's got adapters/spacers.
  8. 65COMET
    65COMET
    A bolt,or stud,is only as strong in length as it is in diameter,so as long as the nut has complete contact you are good.I agree with the others though,that spacer/wheel combo looks scary!! JMO , ROY.
  9. barstowpo
    barstowpo
    I was told that maximum clamping force was achieved as long as you had as many threads engaged as the nut is thick. I hope that makes sense.
  10. henry29
    henry29
    Is that wheel hot pink?
  11. raengines
    raengines
    from pa.
    sure doesn't look safe to me either :eek:
  12. Itchy-Pit
    Itchy-Pit
    120 - 150 pounds on a touque wrench is safe in my world.
  13. Itchy-Pit
    Itchy-Pit
    Then again - the wheel should be flush to the hub and drum - is there a spacer in there??
  14. evintho
    evintho
    Nope, it's cherry red. The camera flash makes it look pink!
    It can't be flush. That's just the way it works. Standard wheel adapter is 1" thick and bolts to the brake drum. I think it'll be safe.
  15. looks like a cast adapter 2 me, shit can the adapter and replace with a machined if ya really have 2 use 1
  16. As long as it's tight your fine,I've run the adapters many times over the years on several different cars. HRP
  17. GOATROPER02
    GOATROPER02
    from OHIO
    I hate wheel adaptors......
  18. That sounds positive !!......I think it'll be safe !!!!! JW
  19. 73super
    73super
    It's fine... don't let 'em scare you!
  20. Roger Walling
    Roger Walling
    In 1969, NHRA had a rule that one complete thread should be visible at the end of the nut. ( I haven't read the book since)
  21. lakeroadster
    lakeroadster
    from *
    Sure it can be done... IF the adapter is made with a stepped bore where the i.d. matches the the axle boss, and the o.d. of the adapter hub matches your wheel. It's very doable.
  22. No fucking way I'd run any adapter without it having a centering hub.
    They seem to Might work fine for 9 out of 10 guys but I wouldn't do it.
    The wheel studs aren't designed to be loaded in sheer.
    The spacers with a counter bore to accept the wheel hub centering and a corresponding lip to provide a hub for the wheel are light years ahead. They cost a few bucks more but they do everything a spacer is "supposed" to do.
  23. Your thread is enough for a lug nut thread,,we really don't need another thread about lugs nuts,,,:D
    Now pictures of lug nuts..that's another thing.:eek::D:rolleyes:;). HRP
  24. Pops1532
    Pops1532
    from Illinois
    The problem won't be the length of the lug bolts. The problem is that spacer you have. Throw those junk spacers in the scrap pile and get some good quality hub centric spacers.
  25. This is the style spacer you want
  26. oldolds
    oldolds
    NHRA rules, no adapters, lug studs must protrude thru the lug nut at least the thickness of the stud. That being said you should be ok. I would rather the machined adaptes, but those are traditional.
  27. genosslk
    genosslk
    Get rid of that spacer NOW! I'm sure you have it in there to solve a clearance problem but you are dealing with a failure at some point. When that failure happens..... and it will..... and you will have guys on here say they are safe but it breaking will cause at lease some damage but can cause a horrible accident. I lost a good car buddy to these spacers as it broke in a hard corner and the car rolled.
    Either have the rear end lengthened or get a different offset wheel to solve the clearance problem.
    Don't trust these spacers!
    my 2 cents......
  28. When I was using the older style adapters the new high tech spacers with a lip were not even thought of.
    Personally, I have the knowledge and access to the equipment where I can modify the hubs and not use spacers of any type,,it's all a matter of preference,,where you agree or not there are a lot of cars out there with the old type adapters. HRP
  29. ago
    ago
    from pgh. pa.
    I would think that is too much torque, depending on the stud thickness and grade. 7/16"-20 grade (5) is 60 ft lbs. grade (8) is 95ft lbs. and 1/2"-20 is grade (5) is 95 ft. lbs. grade (8) 140 ft lbs.
