Technical How is it called and where can I buy it?
Discussion in 'The Hokey Ass Message Board' started by Caprice89, May 13, 2018.
  1. Caprice89
    Caprice89
    Thanks!
  2. Caprice89
    Caprice89
    Thanks!! Where did you find the part number? This will help me search online greatly!
    http://www.gmpartswiki.com/w/3771571&book=125
  3. squirrel
    I have the Chevy truck parts books (similar to the one in your link) so I just looked for it in there.
    If you are clever with building mechanical things, you can probably make your own, It would take a while to design it, though.
  4. GM called it a suburban when it was pickup truck based, it was also called a carry all.
    Rear check is correct on that model if you are looking at GM replacement parts.
    @squirrel check your PMs I got a quick jim question for ya.
  5. Caprice89
    Caprice89
    Even now I know how it's named, I still can't find them. Please show me where I can find/order them? Here in Europe I got nothing, so far.
    Thanks a million.
    Sent from my hand held online shouting device.
  6. Stock Racer
    Stock Racer
    There is a flat door check like this used on the rear emergency door on school buses. I believe they are generic and just screw in place. If I can find something, I'll post it.
    Caprice89 likes this.
  7. rztrike
    rztrike
    They look like the engine hood supports on my 65 Corvair.. I could always measure mine if needed
  8. Stock Racer
    Stock Racer
    This is for the rear door on a Blue Bird School Bus. Its called a door holder. Search buspartswarehouse.com Many different styles available.
  9. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
  10. Quite similar, possibly the same as on (don't flame me guys.......lol ) my off thread 71 k5 blazer rear hatch check worked same, looks same
  11. Caprice89
    Caprice89
    Thanks guys. Got some browsing to do.
  12. hdman6465
    hdman6465
    Sometimes referred to as a butterfly bracket. Fords and Chevs around 1955 use the same bracket. Might try Ford sites, also.
  13. czuch
    czuch
    from vail az
    For info, my 72 Suburbans had the same piece in the rear barn doors.
    Don't judge me,,too hard.
  14. Ebbsspeed
    Ebbsspeed
    To the O/P's credit, he did say cargo doors in his initial post. I believe all other doors on the van are considered passenger doors.
  15. 62rebel
    62rebel
    Trouble with most European CARS is that they might use one, but not two, mirror imaged parts to do that. Maybe larger cargo vans would have them. Personally, I didn't even know GM put them on their panel trucks; I figured the hinges took the brunt of stopping the doors from opening too far.
  16. Squablow
    Squablow
    When dealing with US vendors, it would be best to refer to it as a "panel truck" rather than a "panel van", they have different meanings here.
    I know where one of these panel trucks is, with that style doors on it, but it'll be a while before I could get access to it. Keep in touch, when I get a chance to go out there I can most likely get you a pair of original ones.
  17. Caprice89
    Caprice89
    They actually have a used set! Pricing is bit steep... But that is me being Dutch I guess.
    $175 plus $50 shipping.
  18. s55mercury66
    s55mercury66
    from SW Wyoming
    Glad to hear you found a set.
  19. manyolcars
    manyolcars
    The 49-51 Ford part will probably work. I'm using one for the hood of my 39 Ford
  20. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    Awesome man! They have a great selection of the obscure.
  21. Buddy H
    Buddy H
    I have one that i think is for the right side I would take $50 plus shipping for.
  22. Caprice89
    Caprice89
    Thanks, Buddy. Do you have a picture of it?
  23. badshifter
    badshifter
  24. Panel truck parts are HARD to find, no one makes repo parts so your stuck with eBay or local online (if your stateside). That being said the parts aren’t cheap either.
    By your description I’m assuming you have the barn doors not the clamshell.
  25. Caprice89
    Caprice89
  26. Caprice89
    Caprice89
    I know. All the parts that are interchangeable with the pickup are available, but the panel truck specific ones are hard to find.
    Yes, the barn doors.
  27. Buddy H
    Buddy H
  28. Which is a good thing in a way because a lot (read most) aftermarket parts are junky.......your much better off with stock good parts. They’re out there, I’m on my 3rd panel and finding parts isn’t that bad if your patient.
  29. My hippie wife drives a school bus she turned into a camper. It’s a Thomas, and the back doors have those same door holders, or very similar. I bet they’d work.
    indyjps likes this.
