How does this heater works?
Discussion in 'The Hokey Ass Message Board' started by bonez, Nov 8, 2012.
  1. bonez
    bonez
    from Slow lane
  2. porknbeaner
    porknbeaner
    It goes under the dash should have two water hoses going to it just like any car heater.
    You wire the fan to blow air out into the car and you should be able to run flex duct from it for windshield defrosters.
  3. shinysideup
    shinysideup
    from ruskin, fl
    Recirculated hot water.
  4. I see no water hose connections - are you guys sure it isn't an Electric Heater?
  5. flatheadpete
    flatheadpete
    from Burton, MI
    That's how I read it, too. Electric. No mention of water.
  6. brad chevy
    brad chevy
    Looks like its just a 12 volt self contained electric heater. Not much of a description in the ad.
  7. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Why not give them a call, I'm sure they would be more than happy to tell you how it works.
    KK
  8. kma4444
    kma4444
    If it's purely electric, I would think my answer on how it would work would be, Not Very Well. It takes way too much current at 12v to create much useful heat.
  9. carlos
    carlos
    from ohio
    63-66 chevy truck heater are really simple and compac 3 mounting bolts and 2 holes for your hoses :D
  10. Not very well if it's a 12 volt electric heater,,the one I had was junk. HRP
  11. Dirty Dug
    Dirty Dug
    I've had one of those. It's a hot water heater. Macs sells the same thing for $270.
  12. bonez
    bonez
    from Slow lane
    Thanx. Im in europe, that why im not calling, but other than that, my doubt was exactly that, water or electric?
    If its a water heater it could do. I only have windshield defroster on my daily, and a second unit would help.
    So, any other alternatives? Even vintage stuff, not older than the 60s tho.
  13. Lots of small basic simple to set up water/fan heaters in old pommiemobiles from the 50's/60's. Probably are also in old renaults and such as well.
  14. Gator
    Gator
    I'm 99% positive that's a hot water type heater - the night prowlers guys is a Hamber, do a search, they have a thread going now about there site getting jacked.
    Also, here's an alternative from Summit racing, compact, 12 volt, hot water type, and less than $150 as well.
