Technical How do you paint valve covers?
Discussion in 'The Hokey Ass Message Board' started by atch, Jun 8, 2019.
  1. atch
    atch
    That is:
    1. On a script cover like this one do you paint the orange and then carefully paint the black (maybe hire a skilled pinstriper to do the deed)? Or do you paint the black, let it dry, paint the orange, and wipe off the top of the script before the orange dries? Or do you paint the black and then tape off the top of the script before painting the orange?
    2. And on aluminum finned valve covers do you paint it all and then sand off the high spots? Or do you tape off the high spots before painting?
    I doubt that I'll ever paint any finned valve covers, I like them bare aluminum and have several sets. But I think I'll try to paint a set of Chevrolet script valve covers with two colors.
    Deuces likes this.
  2. flatford39
    flatford39
    On the first one it's like doing license plates. Shoot the black. Let it dry then the orange. Then you lightly buff the script to expose the black letters.
  3. atch
    atch
    Do you let the orange dry first or buff/wipe it while wet/tacky?
  4. Mike Colemire
    Mike Colemire
    I think I'd let it dry real good.
    Deuces likes this.
  5. 29moonshine
    29moonshine
    paint it then get a good pinstriper
    jimmy six likes this.
  6. B.A.KING
    B.A.KING
    On the chevy script, you buy the Chevrolet stick on
    jimmy six, 427 sleeper and alanp561 like this.
  7. squirrel
    All the Chevy script valve covers I've painted have been all orange. The lettering shows well even if you don't paint it.
  8. flatford39
    flatford39
    It's need to be dried entirely. It's a real soft touch with a foam pad. I use a real mild cutting agent like 3M's .....dammit a senior moment. Perfection no that's not it. Let me walk out to the garage. Sorry went and looked and I don't have one. Must have used it. Well use something less abrasive than raw cutting compound and go slow. I have a variable speed two stage buffer that works well here.
  9. Terrible80
    Terrible80
  10. goldmountain
    goldmountain
    On my finned aluminum valve covers I figured that paint wasn't going to stick that well so I cut that red conspicuous reflective tape often seen on the backs of school busses there. Real pain making stencils to fit around the word "Corvette".
  11. hrm2k
    hrm2k
    painted the orange and then used a sanding block with 320 grit...….......…...keep sanding until all fins are the same width ( visually ) and the finish on each rib is the same
    BEFORE BLOCK SANDING
    pitman, Desoto291Hemi and Deuces like this.
  12. On stamped I painted the letters first
    Then the rest ( quality single stage)
    Sanded the main color until the letters showed up. Then cleared. Looked great
    On finned, I paint all of it then sand and polish the fins.
    Deuces likes this.
  13. belair
    belair
    I used a Sharpe on my Chevy script valve covers (hangs head in shame). But the pair is on the wall. What do you do if you powder coat them?
    wraymen likes this.
  14. 6sally6
    6sally6
    Fine grit sanding block after orange is dry. lightly rub it and the script will come out silver. Then leave it that way and clear coat it.
    6sally6
  15. 56sedandelivery
    56sedandelivery
    Paint the black, then allow to dry. Then, with a crayon, cover the script with wax, then paint the orange. Paint won't stick to the wax, then remove the wax. Done. I am butch/56sedandelivery.
  16. 41rodderz
    41rodderz
    from Oregon
    I have always used grease over anything like tags , decals that was not getting painted. On finer lines like the script go buy a fine small artist brush . Take a match book cover or a business card and lay it up close to your script as a guide. You paint the letters , let dry , apply grease. Paint your orange , let dry and wipe grease of script. Patience and do not drink a cold one until done.
  17. enjenjo
    enjenjo
    from swanton oh
    The same as you do with paint, black first, then red, then buff off the letters and clearcoat with powder
    belair likes this.
  18. Ericnova72
    Ericnova72
    from Michigan
    On the finned aluminum, take a thinner soaked rag wrapped around a rubber sanding block and wipe the fins clean while the paint is still wet. Done this way they can be pre-polished. Way easier than sanding them clean after letting it dry.
  19. MantulaMan
    MantulaMan
    For script/detail work you can paint the cover the colour of you script and then go over the letters with grease before you paint the top colour. You can then just wipe off the grease/paint on the script.
    I've be warned off powder coating valve covers as if it's not done properly the powder coat on the underside can come off under engine temperatures and you then get the abrasive powder falling into your rocker gear and mixed with the oil...
    Sent from my SM-G390F using Tapatalk
  20. wicarnut
    wicarnut
    On these, bead blast, taped off, painted black, block sand, clear coat. 5 years +, look as good as day 1 IMG_0615.JPG
  21. clem
    clem
    Can’t believe that there are so many different ways to go about this.
    On my finned covers, I just painted and while still wet, (immediately), took a rag wet with turps, and wiped the top of the fin clean. Was already polished.
    This was about 8 years ago after researching how to go about it, here on the HAMB !
    Rich S. likes this.
  22. I polish the valve cover, clean it thoroughly, mask the outside along with thin strips on top of the fins, paint, and while still tacky, pull the tape strips, and finish removing the paint with a thinner dampened rag. I found taking the time to slice up and apply the tape on the fins; while probably taking longer, gives you an edge on cleaning the paint off the fins.
    Elcohaulic and VANDENPLAS like this.
  23. alanp561
    alanp561
    I can't believe I read through this whole thing and it was all about, ugh, CHEVROLETS. I'm going to go get another cup of coffee:eek:
    Rich S. and 41rodderz like this.
  24. Its just about painting "Valve Covers" just happens to be that Chevrolet owners are PROUD to show off there stuff..
    Not seeing them Blue Oval owners stepping up?
    Rich S. and belair like this.
  25. BamaMav
    BamaMav
    from Berry, AL
    Last set of finned covers I did, I only wanted paint between the fins. I used a small brush, and had a rag with thinner for any goof ups. Just sorta flowed the paint between the fins, then wiped off any that got on top of them. After they were dry, touched up the tops of the fins with fine sandpaper.
    RICH B and '51 Norm like this.
  26. jimmy six
    jimmy six
    OK I'll answer the question....With a spray can...:rolleyes:
    alanp561 likes this.
  27. theHIGHLANDER
    theHIGHLANDER
    On the raised script covers, paint the base color 1st. Take the color of choice for the script, once the main is dry, and use a hard rubber roller (brayer) to apply. Practice a little on an old license plate for the amount of solvent needed to maintain control. Here's some examples from BLICK art supply, but any art supply will have something:
    https://www.dickblick.com/search/?&q=rubber roller&filter=Category_fq:"Paint Rollers"&rows=24&view=grid&start=0
    This so easy you'll want to find all kinds of shit to do it on.
    Finned aluminum, get the whole thing finished to the choice you want. get it really clean and dry then mask all but the raised fins and paint the valleys and sides but not too heavy. Covered, but not thick and heavy. Sometimes a light spray of etching primer helps too, but you have to wipe the ribs while it's wet. Once all in wipe the ribs off and you get a really pro look to the final job with only the valley in color on a fully polished cover. I'm far too lazy to try some of the ideas posted, but that doesn't mean any of them are wrong.
    But what if you have tin covers with logos stamped in? Well, that's where a small brush and edge wiping are the efficient and easy way. Once all colored and fully dry fill in the low stamping with the color wanted and wipe as you go. I try to use a hard backer and relatively lint free wipe with a minimum of solvent, just enough to clean so it doesn't run into the stamping. Plain enamels are best and you can use mineral spirits (hardware paint thinner) to wipe off the excess and not hurt the main color. Have fun...:cool:
    rod1 and Rich S. like this.
  28. That’s how I did mine. Worked perfect.
  29. 41rodderz
    41rodderz
    from Oregon
    You use grease and you cut out the sanding part .:)
  30. LOL, I took the lazy way on the last set myself, they were in bad shape and pretty pitted to start with though. Gold rattle can, black permanent marker and a few shots of clear. At least two years old and still look OK.
