How do you install frame rivets
Discussion in 'The Hokey Ass Message Board' started by bobj49f2, Dec 3, 2009.
  1. bobj49f2
    bobj49f2
    I need to replace the front crossmember on my '37 Buick. It's riveted in and I would like to install the replacement with rivets. I know I can use hardened bolts, grade 5 minimum. I can also use button heads to get a rivet look but I want to use rivets. I've search the forum and only found threads about riveting sheet metal. Can anyone give a description on the procedure of installing actual rivets? Or a link to a web site?
    Thanks
  2. hotrod-Linkin
    hotrod-Linkin
    i've always heated the rivets cherry red,use a bucking bar and an air hammer with a rivet tool attachment. very easy process that one guy can do.
    keep the bar on the rivet shank and buck it down till she's flattened out . use bolts in the holes to keep it aligned and remove them when your ready for a rivet.
    once the riveting starts it's a bitch to line up if you don't keep the bolts in.
  3. 5Wcoupe
    5Wcoupe
    from L.A., Ca.
  4. 972toolmaker
    972toolmaker
    from Garland Tx
    well if you are only doing a few, thats what the ball end of a ball peen hammer is for.DUH
  5. havi
    havi
  6. The37Kid
    The37Kid
    Just Google Big Flats Rivet Co. GREAT People with everything you need. :D
  7. truckdog62563
    truckdog62563
  8. 1952henry
    1952henry
  9. solid
    solid
    set on favorites. Cool stuff. Thanks.
  10. truckdog62563
    truckdog62563
    Owen - I emailed you a while back checking on you and the family but never heard so I figured you'd moved, changed email, or something. Maybe got lost in the spam. So, how've you been? Drop a note if you would. Stu
  11. 29nash
    29nash
    from colorado
    That's it! (Janis Joplin exclaimed; as she completed her rendition of "Lord Won't You buy me a Mercedes Benz)
    One rivet at a time. Air hammer makes it easier, but not required, I've done it with a claw hammer.
  12. brady1929
    brady1929
    good stuff to know
  13. 5Wcoupe
    5Wcoupe
    from L.A., Ca.
    Was looking through a catalog from Restoration Supply Co. today and noticed that they sell "Threaded rivets" (basically a bolt with a rivet head) in Stainless steel.
    Lots of sizes up to 5/16 X 2"
  14. bobj49f2
    bobj49f2
    If you use a claw hammer did just mash the head flat? Do you have to heat the whole rivet cherry red, or just the shaft, that way the red shaft takes the beating and becomes the only part that deforms and the head stays relatively the same shape?
  15. rexrogers
    rexrogers
    Master Carr is a good source for rivets and your local implement dealer usually can sell you small quantity's. Bolting the cross member in and even put a few weld is some hidden areas is a great idea before you buck the first rivet. Once the rivet is through the hole you want 1 1/2 times the diameter sticking out so trim them to length first. a small welding tip works great to heat the up set side a nice controlled flame. practice on some scrap first and look at the other rivets on the frame to tell how much they are bucked or what style the upset head has once you start riveting things together it is hard to stop they look great and kinda fun to do.
  16. hotrod-Linkin
    hotrod-Linkin
    kind of hard to isolate the shaft on a rivet when trying to heat one.
  17. 29nash
    29nash
    from colorado
    Heat the entire rivet real hot, but don't need to be white-hot. Don't pick it up with your fingers, use pliers. Poke it in the hole. Hold a bucking bar against the head firmly. Hit the end that came through the other side.
  18. bobj49f2
    bobj49f2
    Why not?
    Just kidding:D
  19. Angry Frenchman
    Angry Frenchman
    because its heavy lol.
  20. hotrod-Linkin
    hotrod-Linkin
    you'll only do it once.
  21. JRODHOTROD
    JRODHOTROD
    from Manor, TX
  22. Lazer5000
    Lazer5000
    I've got to go with hotrod-Linkin on this one. Heat the thing till it's cherry red than hit it with an air hammer. The whole process only takes a minute.
