How do you block sand a large low crown panel that 'moves'?
Discussion in 'The Hokey Ass Message Board' started by oldrelics, Mar 29, 2013.
  1. oldrelics
    oldrelics
    from Calgary
    and I'm not talking oil canning, there is none of that, the panel is large and when you apply firm pressure to block filler it 'gives' a little. I'm thinking it wont come out straight. Do I just sand it lighter and take alot longer?
  2. slddnmatt
    slddnmatt
    Yep, light as a feather and patience!
  3. s55mercury66
    s55mercury66
    from SW Wyoming
    Just like slddnmatt says, and in the past, if you can, I have put sound deadener panels in place. They can add a little more "stiffness" to make life easier.
  4. fleet-master
    fleet-master
    what Matt said..Also, be sure to keep using sharp sandpaper so that it 'cuts' the surface down without you needing to lean into it. what grit paper are you using?
  5. Pete Van Hoon
    Pete Van Hoon
    Glue something inert and large underneath - thin - to add support and clears lining but only if lining is removed. Plastic maybe.
  6. Ob1
    Ob1
    That problem affects many modern cars; you'd swear the panels arent much thicker than beer cans.
    Light touch, start with a coarser grit than you normally would, keep fresh paper on the block, switch to lighter grades as you approach "flat", switch to an easier to sand filler. I like Evercoat Quantum.
  7. 56premiere
    56premiere
    The qtrs. on my avatar are 105 '' long and were unsupported we had the same problem.I glued cedar 1x stock in. I used a lock tite shower panel glue,they sure helped. Jack
  8. Rusty O'Toole
    Rusty O'Toole
    Used to have this problem, one cure is to stick a piece of styrofoam inside between the inner and outer panel.
  9. brandon
    brandon
    a soft long block ...I use a long durablok
    .....and hit it:D
  10. Tinbasher
    Tinbasher
    I'd get a long AFS sandblock. (36') and a light touch.
    The Old Tinbasher
  11. oldrelics
    oldrelics
    from Calgary
    I'm using 80 grit but I'm gonna go down to 40 grit on a 17" board and give it a whirl. Thanks for the tips! I use Evercoat Lite body filler and Evercoat Metal Glaze Ultra putty. It goes on like smooth icing and sands better than anything that I've ever used. The loooooong sanding boards are $$:eek:$$ so I might have to improvise there...
  12. Boeing Bomber
    Boeing Bomber
    If it's a crowned area, I'd consider a grille brick. The smell can turn some people away, but nothing feathers better, or matches the contour of curved metal better. The real nice part is you don't use a lot of pressure. Good luck.
  13. oldrelics
    oldrelics
    from Calgary
    HUH? Please enlighten me.....
