How do u figure out wat ratio your banjo is?
Discussion in 'The Hokey Ass Message Board' started by DIRTYT, Aug 4, 2005.
  1. DIRTYT
    DIRTYT
    from Warren,MI
    Short of pulling all apart how can i figure it out.. its a 1947 lincoln unit. any one have any specs... Thanks
  2. Sixcarb
    Sixcarb
    from North NJ
    I would guess 3:78, some were stamped on the center section......Bruce Lancaster may have a better answer for you.
  3. Bruce Lancaster
    Bruce Lancaster
    Lincolns of this period mostly had overdrive, along with the close ratio trans--ratios were 4.44 and 4.2something or the other--don't know non OD, but can lookitup. If you have the rear just sitting there, start turning over a drum and count turns of driveshaft for one turn of drum...
    Fords had tooth count (divide to get ratio) stamped on bottom of Banjo--I'd bet Lincolns did too.
    This rear is a Licoln design--no significant interchange with Ford.
