Technical How do I identify different SBC engines
Discussion in 'Traditional Hot Rods' started by HOTRODPRIMER, Nov 10, 2020.
  1. 31hotrodguy
    31hotrodguy
    I know you said the valve covers are bit for sale but would you consider just giving them to me.
    scotty t and 61Cruiser like this.
  2. 31hotrodguy
    31hotrodguy
  3. 61Cruiser
    61Cruiser
    Hi there, this may be different cause my car was assembled here in Australia but my 61 Belair has a 283 with staggered valve covers and has for its whole life. Can anyone shed some light on this for me. I don’t know the casting number of the heads but I’m going to find them next time I have the covers off. Thanks.
    31hotrodguy likes this.
  4. good eye and you got me, should have painted those adapters engine color.. lol :D@56sedandelivery .. little trickery on running the early valve covers on my 283.. can't remember whats on the passenger side exhaust manifold wise..It gets the job done. But I'm running and alternator (not period correct, but it's 12V )..
  5. Bob Lowry
    Bob Lowry
    Although, many guys are doing cloned, small journal 302" Z28 motors, using that 327" and the 283 crankshaft. The 283" forged cranks are going for $200 plus if in good shape. Several years ago you could buy them for $80 already turned. I am putting together this same combo., which is my third one. You may have more worth than you think.
    31hotrodguy and grumpy65 like this.
  6. 31hotrodguy
    31hotrodguy
  7. Dave G in Gansevoort
    from Upstate NY
    Where in NY? If close enough to Gansevoort I'll clean them out for you. I seem to collect old obsolete stuff, I could definitely use a 283 block in the future.
  8. 59Apachegail
    59Apachegail
    from New York
    Dave I’m about 3 hours south of you, not far from your hotel : )
    *edit someone already scored the 327
  9. redo32
    redo32
    Bump! Just to remind @HOTRODPRIMER that we are still hanging.
  10. atch
    atch
    Yes; we are...
  11. jimvette59
    jimvette59
    Yes the last 327-350 HP. If I remember correctly.
  12. Ray Luthye
    Ray Luthye
    Just picked up a late 70’s 350 and it fooled me. The crank flange looks like the 400 on the chart, but after disassembly found it is a 350. Looks like the chart does not apply to cranks after 1974. Darn, really excited to see how the 400 shaft was machined to fit in the 3970010 two bolt block! Lol!!
  13. olscrounger
    olscrounger
    The LS swaps are allowing some nice early motors to be available--bought two great running small journal 327's from guys doing the LS swaps. One was fresh with 600 miles-built right too-put it in a 40 coupe-strong runner!
  14. A Boner
    A Boner
    Bump for Danny
  15. ekimneirbo
    ekimneirbo
    If its a good deal, it may get away if you spend too much time "verifying". If the guy wants them gone, give him what he wants.....or make him an offer since they are virtual unknowns.
    Take em home and sort them out and sell what isn't useful.....hopefully getting your money back while still keeping some of it.
  16. Torkwrench
    Torkwrench
    I have a 1958 PowerPack 283 that has staggered valve cover bolts and accessory bolt holes. The bolt holes are only on one end of the heads, though, (driver's side front and passenger side rear). It was pulled from the car in the mid 70's and definitely has not been apart. The date codes on the heads match up with the block and intake date codes, and are 1958. When I got it, the bell housing and 3 speed trans. were still with it. These also have 1958 date codes.
    My older brother has a 59 2 bbl. 283 with the same style heads, (although they are 2 bbl. heads). He pulled this engine out of a 59 Impala that had been untouched in a farmer's field since the mid 1960's. These heads were early 1959 date coded, with staggered bolt holes, and accessory holes on one end of the heads.
    I recently learned that these bolt holes were for the air compressor on air suspension equipped cars.
    Another little detail to date small blocks are the front cover bolts. 1961 and older engines used flat screwdriver headed bolts, while 1962 and later used hex headed bolts.
    Also, the engine photo shoes the earlier style harmonic balancer with bolt on pullies. However, as far as I know the 55 - 57 balancers had the pullies riveted on.
    58 Chevy PowerPack 283 in Barn A.jpg 58 Chevy PowerPack 283.jpg 58 Chevy Trans.jpg
  17. sunbeam
    sunbeam
  18. Lift them. If you can easily lift the entire engine with one hand, it's a 283 or smaller. If you can lift with one hand but it ain't easy, it's a 307 or a 305. If you need both hands it's a 327/350. If you need both hands and an extra pair of hands it's a 400. Jeeze, even my wife knows this o_O
    Budget36 likes this.
  19. Ebbsspeed
    Ebbsspeed
  20. Greenblade
    Greenblade
    Ever get to look at the engines?
