Hot Rods How do I fix THIS?
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Oct 17, 2019.
  1. flynbrian48
    flynbrian48
    There. I fixed it. And discovered I’d also put a screw into the wiring harness. So I get to fix that too...
    Rramjet1, loudbang, Sporty45 and 4 others like this.
  2. BJR
    BJR
    So tell us how you did it!:)
    loudbang and flynbrian48 like this.
  3. TrailerTrashToo
    TrailerTrashToo
  4. Looks freakin' factory..
  5. flynbrian48
    flynbrian48
    Gorilla tape, when it moves but isn’t supposed to...
    egads and loudbang like this.
  6. MrPhat40
    MrPhat40
    We just knew you could do it yourself.
    Plus you learned something. As the great Gene Winfield says: Everyday is a school day.
  7. flynbrian48
    flynbrian48
    Hahaha, thanks! And, I bought a new tool to fix it with, so BONUS! Everybody needs a propane soldering torch, right?
  8. flynbrian48
    flynbrian48
    Soldering torch, a roll of solid core 50/50 solder, a tin of flux, all from the hardware store for less than $50. Winning. Now, I need to be careful where I up those screws....
    Blues4U, loudbang, BJR and 1 other person like this.
  9. loudbang, G-son and TrailerTrashToo like this.
  10. Garpo
    Garpo
    I worked in a brake repair shop where we would make up new pipes to samples.
    Lost count of the pipes that came in with a drill or screw hole through it.
    Seems where ever you want to drill, there is a 90% chance that there will be some thing on the other side that should not have a hole in it.
    Garpo
    flynbrian48 and loudbang like this.
  11. Those of us that do home plumbing often use a Bernz-o-matic torch to sweat fittings. I get a tank of Mapp gas, burns hotter than propane.
  12. LOL! So is that a side effect of prolonged lead exposure? :oops:
    :rolleyes:
  13. Mike51Merc
    Mike51Merc
    Glad you got it done, but I still gotta believe that core could be removed from the plastic housing. If it was assembled, it can be disassembled.
    Just to add a little anecdote: A buddy of mine years ago told me he had a leak in his dining room wall that was staining the sheetrock. I went to investigate and found a sheetrock screw had punctured the upstairs drain stack and when it eventually rusted through, the waste line was dripping inside the wall cavity. Yuck.
  14. fordflambe
    fordflambe
    This reminds me of the time i was installing a dog door for my wife............Removed the door. Took it to the shop and installed the dog door. Brought the door back in and installed it............Dog door was on the top of the door.........OOPS! (for real!)
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    If the shiny substance on the copper tubing is excess flux , be aware flux is acid and will continue to eat the copper....
    kidcampbell71 likes this.
  16. flynbrian48
    flynbrian48
    Really tall dog?
  17. flynbrian48
    flynbrian48
    That is what I intend to do all winter. Once I get done repairing all I've broken, cut wrong, mis-wired, taken apart and re-done, the car will be finished!
  18. fordflambe
    fordflambe
    After laughing her ars off, my wife coined the name "butterfly door".
  19. 41woodie
    41woodie
    He's right
  20. Seems to me that a feller could get himself into a heap of trouble making a statement like this on a public forum. o_O Good thing that her sense of humor is still intact. :D
    fordflambe and G-son like this.
