Hot Rods How do I fix THIS?
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Oct 17, 2019.
  1. flynbrian48
    flynbrian48
    This is the heater core in the A/C/ heat from Southern Air I’m putting in my ‘63 Riviera. See the little hole? What are the chances that a sheet metal screw holding a block off plate on the firewall would find that particular spot to enter the core? I couldn't be that accurate if I'd been trying to hit it...
    If said 100%, you are correct. I tried my soldering gun but it won’t heat the copper enough to melt solder. I don’t believe I can get the core out without wrecking the plastic housing, and there’s no way, I don’t think, to use a flame to heat without ruining everything.
    A sheet metal screw and JB weld came to mind, but I’m not quite to that level of hillbilly repair...
    Stogy, loudbang and chryslerfan55 like this.
  2. goldmountain
    goldmountain
    Cut a larger access hole in the plastic, solder with a jewellers torch and make a larger cover for the hole with sheet metal
    Sent from my SM-T350 using The H.A.M.B. mobile app
    deathrowdave, alanp561 and loudbang like this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you have a soldering iron (, not a gun) that wouldn't be too difficult , clean , flux , tin ,solder. If you want to silver solder it , you'll have to remove it from the enclosure ...
    nunattax, Stogy, alanp561 and 3 others like this.
  4. Bird man
    Bird man
    from Milwaukee
    Thanks for the hearty laugh.
    Yeh, BTDT!
    Who hasn't?
    Stogy and loudbang like this.
  5. flynbrian48
    flynbrian48
    I have a soldering iron, but it's small, it seems to barely get hot enough to melt solder on the tip, let alone anything else. So perhaps it's not enough. I'll try a getting a better one. I'm aggravated at myself for doing this, but I've done similar things before. Like putting a drywall screw into a 14-2 hot wire in my little camper, on the last piece of trim in the interior, that instantly made smoke come out of all the sockets...
  6. Paul
    Paul
    Editor
    Just thinking out loud, I wonder if a brass screw inserted into the hole would absorb and transfer heat better to accept the (better, hotter) solder gun method than copper alone..
  7. TrailerTrashToo
    TrailerTrashToo
    Brass screw adds thermal mass, requiring an even bigger soldering iron or gun.
  8. KevKo
    KevKo
    from Motown
    When I was young, stupid, and poor (still 2 out of 3) I had a '63 Nova. Was patching the floor. Drilling holes and screwing the patch in when I smell gas. I drilled into the fuel line, dead center. I cut it and slipped a piece of rubber line over it.
  9. nochop
    nochop
    from norcal
    Solder, silver soldering might be a tad to hot thus risking unsoldering adjacent joint rendering the whole unit unusable.....ask me how I know....
  10. G-son
    G-son
    from Sweden
    A bit tricky with plastic around, but I'd call that a perfect spot for making such a damage - very good chances to solder a repair there, you just need enough heat.
    I've repaired a number of brass/copper radiators and heater cores for friends, and a neat hole in thick metal like yours would be a dream to work with compared to most off the stuff they've brought to me.
  11. Bryan, you are good? ;).
    I found the exact same problem on a tube in an original, unused, Mark IV under dash AC unit. A screw attaching the outer cover was off a fraction and punched the tube. FROM THE FACTORY. I had mine repaired at the radiator shop.
    Ben
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    I meant a soldering iron that you heat with a burner , guess I am out of touch ..
    Another thought , what's that paste that stops welding heat ??
    Heat sink or some such ???
    Possibly a Jewelers torch , one of those butane ones ??
    Stogy, flatford39 and loudbang like this.
  13. 2OLD2FAST
    2OLD2FAST
    from illinois
    Would you cover the hole with flat copper ??
  14. G-son
    G-son
    from Sweden
    Might be easier to put a solid piece of copper from an electric wire or something like that in the hole and solder that in place, than a big piece of sheet to cover it. At least if you are unsure about having enough heat for a proper job, the bigger the area to solder, the more heat you need.
    Assuming there are no electric fans or other sensitive bits in there you could lower the assembly into water, and put wet rags over the plastic above the surface. Can let you get a big torch in there without burning anything up.
    trikejunkie, VANDENPLAS and loudbang like this.
  15. F&J
    F&J
    X2 on the old soldering iron which is just a big piece of solid copper. There are older electric ones that also have the large copper tip. Both would seal that hole in literally just a few seconds.
  16. MrPhat40
    MrPhat40
    Re: your comment that your soldering iron will barely heat up to melt solder on the tip. I would suggest you thoroughly clean that tip and make sure it is properly;y tinned. With out tinning the tip will not transfer enough heat to melt the solder.
    Before you attempt to close that hole clean that copper pipe with Emory cloth and then flux it. You will be amazed at how well solder flows when it is applied to a properly cleaned joint or in this case hole. First three rules in soldering:
    1) Clean
    2) See rule #1
    3) See rule #1 and clean some more.
    Also what about a pencil torch? Heat that cleaned copper pipe and flow the solder to the hole.
    Good Luck
    MrPhat40
  17. Budget36
    Budget36
    I'd think you could put a short screw back in it, tighten well, then silver solder it.
    Paul and loudbang like this.
  18. Marine-tex will fix damn near any thing....
  19. Bandit Billy
    Bandit Billy
  20. Okay, I know just a little about most things and enough to steer clear of Trouble on some things. I'm going to go out on a limb here and say that from your above comments you also are in that class of a little about most. Being this repair seems easy enough it sounds like you don't have the right equipment to do the job like a real Rad. shop would use. I will also say that in the right hands that repair is so simple you'll always feel like you should have done it yourself. Myself I'd open up the housing just a bit more so I can see the end of my heat travel and control it. 5 minuets including clean up and it's done in the right hands. Just pay what it takes and be happy you didn't make Scrap metal out of it. Go to your local radiator repair shop, you'll be glad you did in the long run.
  21. I'll add this. You don't just solder the hole shut. You make a small patch and arch it to match the tube, tin both parts and add the patch over the hole. Keeps from plugging up the core with fall through solder.
  22. redo32
    redo32
    I would tig with phos copper rod. Do it fast it won't melt much
  23. The Shift Wizard
    The Shift Wizard
    I agree with our friend from Sweden. Anybody that repairs radiators could knock that out in 5 minutes. Wrap a $10 bill around it and take it to a local shop if you're skeered of doing it yourself.
  24. Blues4U
    Blues4U
    from So Cal
  25. Blues4U
    Blues4U
    from So Cal
    Even better, do a search for 100 watt Hexacon soldering irons on ebay, there are several available on there, even some larger; for less than that cheap Weller.
  26. Use a butane soldering iron (carefully).
  27. Rex_A_Lott
    Rex_A_Lott
    Muratic acid will do a good job of cleaning it, to get it ready to take the solder. 50/50 is the best solder , if you can find it. Most of the the stuff you see now is 90/10, since everybody is so scared of lead. Amazes me, the most dangerous thing you do is get behind the wheel and drive, you can get killed at any minute, but you cant buy lead solder because if you are stupid enough to eat a couple of pounds of it, it just might kill you someday.
  28. Ebbsspeed
    Ebbsspeed
    If you lived anywhere close to me I'd:
    1. Take two beers out of the cooler for us and set them on the workbench.
    2. Fix the hole.
    3. Open the beers before they had warmed up 2º, hand one to you and drink them.
  29. sunbeam
    sunbeam
  30. winduptoy
    winduptoy
    So...the original connections are done with 15% silver solder so you can get away with soft solder...lower melting temperature on this than the original joints. You want to use a soldering iron instead of an open flame around the plastic
    Go to your local plumbing supply house and get a bottle of Soldering, Tinning flux.
    I use Harris 'Stay Klean' but any tinning flux will work
    Use a soldering Iron as suggested...get high enough wattage
    95/5 solder will have higher strength and 50/50 will probably be hard to find as the lead content is unpopular and even outlawed...now I know this really makes you want to use the 50/50
    Clean the area around the pipe with some sand cloth while preheating your soldering iron
    Put some tinning flux on the area to be repaired
    Put some tinning flux on the hot tip of the soldering iron along with some solder and get it shiny silver
    Place the soldering iron over the hole trying to get as much contact with the pipe as you can
    Keep trying to apply solder at the junction of the soldering iron tip and the pipe...suddenly it will wet and flow
    Play the iron on the pipe and lift it so as to leave the hole covered.
    Piece of pie......
    Or send it to me and I'll send it back repaired
    Larry
    leon bee, chryslerfan55 and alanp561 like this.
