hot rod tach wiring help
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by greenracer, Dec 6, 2009.
  1. greenracer
    greenracer
    from sequim wa
    have a WICo tach with 3 wires and cannot figure it out 1 is the light where do the others go???
  2. nico32
    nico32
    from fdl, wi
    What colors are the wires and is there a model # on it at all?
  3. greenracer
    greenracer
    from sequim wa
    red white and black. The red goes straight to the light
  4. nico32
    nico32
    from fdl, wi
    Black should be your ground and white should go to your coil then.
    I'd run a quick test on it to verify the light works using the red and the black.
  5. PegLegStrick
    PegLegStrick
    Welcome from South Georgia :D
  6. greenracer
    greenracer
    from sequim wa
    I have tried white to coil and black to ground touched it and tach jumped past 8 grand then i tried connecting tach between ing side of coil and coil did the same thing Jumped way past 8 grand????
  7. nico32
    nico32
    from fdl, wi
    What's it out of, could it be that it came out of a positively grounded vehicle?
