hot rod deck lid latch options...
Discussion in 'The Hokey Ass Message Board' started by touchdowntodd, Jun 3, 2008.
  1. touchdowntodd
    touchdowntodd
    lets see some non-stock deck lid latches, or any other way you are holding down the trunk lid on your hot rod... bouncin around they are loud and no fun hahahha
    i need to do something and have been kickin around ideas, i just know i wanna stay away from stock ... what have you done? pics if possible!
  2. GREASEMONKEY72
    GREASEMONKEY72
    could do a set of hood pins
  3. 325w
    325w
    from texas
    I used a small latch from Micheal's cable operated. Could e-mail pic. have not figured out the post deal ??
  4. zzford
    zzford
    Though not very secure, a strong magnet. My trunk latch is off a small Jap car. A walk thru a U-Pick junk yard will reveal a wide selection of usable latches.
  5. touchdowntodd
    touchdowntodd
    yeah i know i could use just about anything, just wantin to hear some ideas and see some pics maybe... something to spark the imagination
  6. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Zeus fastners? I am not sure how you spell that but they started showing up after WWII.
  7. GREASEMONKEY72
    GREASEMONKEY72
    thatd be cool, just dont forget the screw driver
  8. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Especially if your tank is located in the trunk!!!!
  9. panheadguy
    panheadguy
    from S.E. WI
  10. Dzus fastener fwiw.
    I open mine with a dime.
    Take a look at SUVs and Soccer Mom vans in the junkyard.
    Many of them have nice Bear Claw type latches and would be easily adapted.
    Plus, most of them have an electric solenoid attached.
    Small aftermarket Bear Claw on my 31 A roadster.
    Note that it's shimmed out 1/8" on the inside.
    The pics show the shim on the outside and also with the supplied latch pin that wasn't used.
    I used a bent headless 3/8" stainless bolt instead.
    Cable operated, an Explorer latch - if I remember right works well.
    The 31s latch is cable operated with a diesel accessory pull cable.
    Fairly heavy duty it is.
    The threaded adapter is home-made.
    This last pic shows the final install.
    Fairly clean.
    The thinking was setting up a latch that didn't get hung up on stuff.
    Although, the latch pin on the trunk lid is a bit of a head-banger till you get used to it....
    dana barlow likes this.
  11. moses
    moses
    leather dog collers cut in half and screw onto bady and trunk lid...jeffrey
  12. Ah man,,,you just made me realize that's something else my roadster don't have,:rolleyes: HRP
  13. lowmaster
    lowmaster
    I used a garage door t handle on my 27 from Home Depot. It even came with a key.
  14. Shifty Shifterton
    Shifty Shifterton
    Bear claw mini latch actuated by an early 50s XK120 trunk handle. Factory still sells em brand new with keys, real graceful looking.
  15. VA HAMB
    VA HAMB
    Sorry no pics but I use model A hood latches on my T coupe.
  16. Sparkswillfly
    Sparkswillfly
    from Colorado
    I was kicking around using a VW deck lid latch, you can still buy them new and they have a lock......just an idea.
  17. gearheadbill
    gearheadbill
    Kinda hard to see but here's a steamer trunk latch on one of my old roadsters.
  18. Kevin Lee
    Kevin Lee
    Super Moderator
    Hood hold downs work as well.
  19. touchdowntodd
    touchdowntodd
    i would like to see better pics of the steamer trunk latch, or someone that is using hood hold downs...
  20. Evel
    Evel
    1. 60s Show Rods
    I got a good solution for my coupe.. it rules but I need to shoot some pics,,, I'll
    get onit and post it,,
  21. Harris
    Harris
    I was considering using the hood latches off a newer Jeep wrangler - very easy install, still sold new, and a ton of aftermarket versions.
  22. Jacksmith
    Jacksmith
    [​IMG]Watson's Street works sells this set up... pretty simple & not real $pendy... I like it because it can be used with a cable or a solenoid.
  23. gnichols
    gnichols
    from Tampa, FL
    ^ Reminds me of a VW Beetle latch. Same?
  24. Jacksmith
    Jacksmith
    Dunno, but they look use-able, depending on the application...
  25. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    No-see-am;
    Choke cable/gas cable< now lawnmower parts.
    Run to under seat or a like,just pulls a pin,so trunk can be lifted/opened.
    Pretty old post,but others look for ideas too.
    Stogy likes this.
  26. adam401
    adam401
    Wow took us 12 years to get here. Crazy times were living in.
  27. Dave Mc
    Dave Mc
    I am using a Springloaded Tailgate latch from a pickup in my 33 , operates with linkage to a Harley D. Clutch handle.
