Horn Relay Q
Discussion in 'The Hokey Ass Message Board' started by vintagesurvivor, May 11, 2006.
  1. vintagesurvivor
    vintagesurvivor
    from detroit
    I have an aftermarket horn relay, and on it it has 3 terminals labled H B S.
    H I take to be HORN. What is the B and the S?
    Mark
  2. flathead okie
    flathead okie
    bull - shit
    Sorry nothing helpful. The last horn and relay I bought came with instructions. I put them up somewhere incase I had to re-wire. I'll look for them when I get home and see if it helps any.
  3. jalopy43
    jalopy43
    one must be power +, and the other s switch(button)?
  4. vintagesurvivor
    vintagesurvivor
    from detroit
    Hron, Battery, Switch? That might be it!
  5. flathead okie
    flathead okie
    Sorry the relay I have has 4 connections, and thier numbered 30-85-86-87. The H-horn, B-battery, and S- switch sounds the best to me.
  6. Paint
    Paint
    The H terminal goes to the horn, the B terminal is 12 volts (or 6 maybe) from the battery hot all of the time, and the S goes to your horn button. The horn button should actually be a ground circuit,so if you ground the S terminal with the horn and battery wires hooked up the horn should blow.
  7. vintagesurvivor
    vintagesurvivor
    from detroit
    Hey Paint, you're right around the corner! Im at 12 and Schoenherr.
    Thanks for the heads up , I want to wire a horn up to the Survivor, what with all the nutty drivers out there today!
    Mark
  8. Barz51
    Barz51
    Here is a diagram I found on another site. If you just have for terminals you probably don't have 87a, the normally closed circuit. Good Luck.
  9. mikeyboy
    mikeyboy
    30. B+ supply
    85. ground (connect to horn button wire if it grounds when pressed)
    86 12 v switched (you can connect this to 30)
    87 12v out (to horn)
    if the horn button completes a circuit & sends power down the column,connect the 85 pin to ground & the hot horn wire out of the column goes to 86
  10. vintagesurvivor
    vintagesurvivor
    from detroit
    I only have three terminals labled H , B , and S.
    I will hook the horn to H and ground, B to Battery HOT all the time, and S to switch GROUND.
    Mark
