Horn not working
Discussion in 'The Hokey Ass Message Board' started by phatgoose, Aug 6, 2010.
  1. phatgoose
    phatgoose
    I have a '50 ford shoebox. 8ba Flatty. I recently installed new factory reproduction wiring harness, new horn relay, new horns, new battery, and 12v conversion. everything works - lights, turn signals, gauges, etc. - except the horns. When I connect the horn directly to the battery they go off but nothing from the horn ring on the steering wheel. Am I supposed to wire the horn relay differently since I converted to 12v? Any info would be appreciated. Thanks in advance!!
    goose
  2. dadseh
    dadseh
    wheel button is an earth... wheres it coming from?
  3. chuckbob
    chuckbob
    Could be that you have a reversed wire connected to the horn relay. It is not uncommon to have something not work exactly right after conerting from 6V pos to 12 v neg. Try a jumper from the horn wire that is going up to the horn button and then touch it to a ground. If the horn blows, then the horn button is at fault. if it dosen't, then check the relay wiring again.
  4. johnny bondo
    johnny bondo
    from illinois
    get a new 12 volt relay. first check the continuity on the horn button/ring with an ohm meter. if it goes from zero to something when you push the button then you are good there.
  5. DocWatson
    DocWatson
    ..................Watch for finger?
  6. That's not such a problem.
    The seatbelt buzzer on my Studebaker Hawk stopped working many years ago.
    I have learned to live without it.
  7. phatgoose
    phatgoose
    Yeah I know, but it I figure its better to have a horn that works in case some idiot on the road isn't paying attention . I wouldn't want to wreck my ride on the account of malfunctioning horn....and we got plenty of bad drivers out here in L.A. !!
  8. phatgoose
    phatgoose
    But thanks for all the info. will try again tomorrow!!
  9. carcrazyjohn
    carcrazyjohn
    from trevose pa
    CHECK THE CONTACT RING FOR RUST... Sorry about the caps..
  10. 68 truck
    68 truck
    from Kansas
    ground between the column and the rest of the car
  11. mrforddude
    mrforddude
    Hmmm... Seems to be the same first thought that I had...
