Customs HORN BUTTON SPARK?
Discussion in 'The Hokey Ass Message Board' started by 59IMPALER, Mar 18, 2016.
  1. Been messin' with the 53's horn button trying to make the new Taiwan horn ring work. With the horn ring cap off, I can see a little spark happening in there when the horn is honked. Is that supposed to happen? I can see why it might do that. When you put the negative cable back on your battery, there's a little spark . So why not the horn button?
  2. OLDSMAN
    OLDSMAN
    Yes it will spark when the horn is honked. You re grounding the circuit and it will spark, nothing to be alarmed about.
  3. khead47
    khead47
    Just go easy on the tacos!
    59IMPALER, slack and bald_and_grumpy like this.
  4. funk 49
    funk 49
  5. Spontaneous electrics of the sonic wave machine's mechs'. AKA honkage. Synonym - beep beep
  6. If you think that's startling, you should see the fire flying around in your distributor cap at 50 MPH! :eek:
    kidcampbell71 likes this.
  7. Relic Stew
    Relic Stew
    from Wisconsin
    You could add in a relay. The button will carry much less amperage then. If the horn is aftermarket, a louder replacement, etc. a relay becomes more important.
