Technical horn button removal?
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Feb 1, 2019.
  1. oliver westlund
    oliver westlund
    so today i got to pick through not just 46-48 ford and mercury heaven but car guy heaven, i picked up a wheel for 30 bucks and now i cant get the dang horn button off! on my 53 ford and my 54 ford you push down and twist counterclockwise. is that what should be the case here too? 20190201_172101.jpg
  2. oliver westlund
    oliver westlund
    has anyone taken one of these off?
  3. did you try just pulling it off?
    oliver westlund likes this.
  4. oliver westlund
    oliver westlund
    sort of...i dont know how hard is too hard... i played college football and im kinda a big guy. i dont want to break it!
  5. s55mercury66
    s55mercury66
    from SW Wyoming
    I think @junkyardjeff had a thread on here a month or so back on this same thing.
  6. oliver westlund
    oliver westlund
    the only one i found by him was a broken chevy horn button
    lowrd likes this.
  7. Jim Bouchard
    Jim Bouchard
    If I recall correctly the button turns something like a quarter turn counter clockwise and comes off.
    Something like two or three tabs on the backside of the button that have raised nubs that as you turn, tighten up a ramp like plate in the steering wheel.
  8. oliver westlund
    oliver westlund
    yeah i pried it off, it was so rusted theres no way it was letting loose, also the steering wheel is fused to the nut and the column, any advise on that? just drill it out?
  9. GordonC
    GordonC
    I got the trim ring for that hanging on a post in the shop. Let me get a pic of the backside and post it up to see if it will help. Give me a couple minutes...
  10. choptop40
    choptop40
    Soak it in pb blaster...she'll come loose...you'll require a steering wheel puller..autozone will loan you one for free...Google steering wheel puller...Do Not Hit The Shaft with a BFH....
  11. GordonC
    GordonC
    Ok. Here are a few shots of the backside of the horn ring. It looks to me as if you press down hard on the center area and the 3 tabs are rotated out from under their lock ring and then it lifts off.
  12. oliver westlund
    oliver westlund
    thanks!
  13. oliver westlund
    oliver westlund
  14. oliver westlund
    oliver westlund
    i have a steering wheel puller, its just that its so corroded in there the center nut is disintegrating, ill try pb blaster first though!
  15. GordonC
    GordonC
    If you need a trim ring you can have it. Chrome is no good but its all in one piece and the button isn't too bad. Just pay for shipping.
    tb33anda3rd and oliver westlund like this.
  16. oliver westlund
    oliver westlund
    thatd be awesome! how do i get the shipping money to you?
  17. GordonC
    GordonC
    Shoot me your address info in a PM and I will throw this in a box and get a shipping cost. You can do a paypal. I'll put the details in a PM.
    Squablow and oliver westlund like this.
  18. oliver westlund
    oliver westlund
    message sent! thanks again
  19. oliver westlund
    oliver westlund
    anyone know the thread pitch for the pulling screws for a 46-48 steering wheel? the holes are trashed and i want to run a tap through em
  20. ClarkH
    ClarkH
    I think it's 5/16 - 24.
  21. oliver westlund
    oliver westlund
    thank you
  22. oliver westlund
    oliver westlund
    all right now cmon! i have been fighting this for two days now, it has soaked in pb blaster, it has been drilled, pried on and beaten on, my steering wheel puller left a dent in the bolt i stuck in the hole! im about to lose my mind here 20190203_183253.jpg
  23. FlyingRN
    FlyingRN
  24. oliver westlund
    oliver westlund
  25. FlyingRN
    FlyingRN
    Torch... Like oxygen/acetylene... last ditch effort normally, but always works!
    Sent from my SM-G960U using The H.A.M.B. mobile app
  26. oliver westlund
    oliver westlund
    my only concern is all the plastic melting
  27. I probably would not have stuck a bolt in the shaft hole.. Get the bolt out and try hitting the shaft ( its tapered). I 'm sure that woodruff( key is seized) .. try also tapping around on the end of that as well. My wheel took a little work before the puller popped it from the shaft.. But there is a lot of rust...
  28. oliver westlund
    oliver westlund
    ill give that a try, its really in there haha maybe i could drill most of the shaft out?
  29. s55mercury66
    s55mercury66
    from SW Wyoming
    You could try an air chisel with a punch. Vibration will loosen things up, some heat applied to the shaft would help too. I can't tell if you have the column still attached, if not you could heat the shaft from the bottom. Pack some wet rags around the parts you want to keep cool, apply heat, and some penetrating oil. Let it cool, the shaft will shrink.
  30. oliver westlund
    oliver westlund
    no, shaft was cut out long ago then left outside like this hence the rust! thats a great idea too, much appreciated! sometimes when i get frustrated its hard to see some simple paths to success
