Technical Hood scoop for a custom question
Discussion in 'Traditional Customs' started by v194, Jul 16, 2018.
  1. v194
    v194
    from The South
    Looking to use a 68 Cougar hood scoop from either a GT-E or a XR7-G But I don't know if there is any difference between the two. Does anyone have one to measure across the front between air openings? What is the difference between the two?
  2. Fortunateson
    Fortunateson
    Oh oh..... '68 you say? Prepare to move on as the Forum Police are heading your way! On the other hand if you are using it to customize something from '65 on back they may let you off with a warning.
    These are GT-Es, I believe the XR7's used the top scoop. No idea on dimensions.
  4. 57JoeFoMoPar
    57JoeFoMoPar
  5. Top scoop is the GT-E with the 427; lower is the 428 version. The very last 427 to be offered by Ford in any car, it only came with the C6 and no ram air, and was also the only 427 to feature hydraulic lifters (and detuned to 390 hp). Replaced mid-year by the 428CJ which could be had with ram air and a 4-speed.
    If you have a original 427 GT-E scoop, some restorer will give you a pile of cash and a testicle for it...
    VANDENPLAS likes this.
  6. dan31
    dan31
    Great looking muscle car scoops for ,you know... a muscle car.
  7. Try the aftermarket for reproductions and get the dimensions from them. these must be reproduced somewhere, Uncle Google is your friend.Good Luck.
